Remove power steering pump?
Old Aug 27, 2007 | 01:45 PM
SilvaDragon's Avatar
SilvaDragon
Default Remove power steering pump?
OK, for you track denizens, did you remove the power steering
pump? Why or why not? How much weight does it save?
Which belt did you use? Loop back the rack or disassemble it
and remove the seals?
Haven't seen any discussion about this...
Old Aug 27, 2007 | 02:02 PM
BlackZ06's Avatar
BlackZ06
Couple of thoughts ...
1) You might try posting this in the track/racing forum ... more likely to get an answer there
2) I hope you have a lifetime contract with a fitness center ... on track I suspect the steering would require some muscle ... in the paddock you'd need a gorilla to move the wheel ... those are BIG tires with a lot of weight on them up front .....
Old Aug 27, 2007 | 02:20 PM
SilvaDragon
Hey - thanks for the tip - I didn't even realize there was a
Racing forum...
To Remove power steering pump?
