Fuel gauge question
Old Aug 27, 2007 | 02:37 PM
Kingman99's Avatar
Kingman99
Default Fuel gauge question
Hi
On saturday when l started my 02 the gauge showed empty and the message center read "low fuel" Now l realized that l was low but l thought l had at least 4 gallons left and was going to get it fueled up.
So just to be safe l picked up a gallon and a half in a gas can and added it to the tank.
The next day l started it to take it for a fill up and the gauge now read 1/4 tank and no message. Keep in mind that the interior of my garage was very hot (weather) and very humid.
Should l be concerned or is this just one of those things, l still have the GMPP extended warranty.
Alan
Old Aug 27, 2007 | 03:14 PM
C6NRED's Avatar
C6NRED
If you do a search on the forum for "fuel gauge" or something similar, you will come up with more information that you can read in an afternoon.....
If you still have a warranty and it covers this problem, get both sending units replaced. This is a very common problem with our cars. There are two fuel tanks and when one sending unit gets sulfer or other corrosion on it and the sending units don't agree with each other, they will go into default mode, and indicate empty.
After getting new ones in (or if they do not cover it...) put Techron in your tank every couple of 1,000 miles and use nothing but Chevron or Texaco gas as both have techron in them.
I had this problem in my 98 and I put a double dose of techron in the tank this past winter while the car was in storage and have been using nothing but Chevron gas, and so far, the problem has not reoccured.
Old Aug 27, 2007 | 03:16 PM
jirasvet's Avatar
jirasvet
I would be concerned seeing how the c-5 fuel system has its flaws. would not want to run out of gas. There have been several post on fuel problems so do a search on the forum. I had to have on my 2003 the whole fuel system replaced, both tanks, pumps and sending unit. All that for an erratic fuel gauge. Had warranty coverage
Here are some links to service Bulletins:
http://www.corvetteactioncenter.com/...ram+the+PCM%29
http://www.corvetteactioncenter.com/...mp+Assembly%29
http://www.corvetteactioncenter.com/...Gauge+Readings
Here is a link that describes current fuel system:
http://www.corvetteactioncenter.com/...el+Tank+System
Old Aug 27, 2007 | 04:37 PM
TAZZVETTE's Avatar
TAZZVETTE
I use the Chevron Techron Concentrate Plus @ every 3000 miles and no more problems!! Give it a shot
Old Aug 27, 2007 | 05:21 PM
Kingman99's Avatar
Kingman99
Ok this has only once but there is always a first time before many more!
Is it worth bringing it in and what happens if it doesn't happen when the tech looks it over or is it just my word?
Does this throw a code?
And what should tell the service advisor before he puts me off. I have the GMPP extended warranty with a $100 deduct.
What if the service advisor says to only replace one sending unit?
This is not what to say but how to say it. Should l tell him that l'm aware of the bulletins?
Alan
Old Aug 27, 2007 | 05:38 PM
TNX ZORA's Avatar
TNX ZORA
Since this is likely a sulfur build-up problem that it likely resolved by the use of Techron, I would avoid the risk of entrusting my car to a car dealer.
Old Aug 27, 2007 | 06:20 PM
Kingman99's Avatar
Kingman99
Default Trusting a dealer???????????
Your 1000% correct and my extended warranty runs out in 2010 so l will heed your warning!!!!!!!!!!!!!
Being that l don't have a mar on my car as of yet, so why tempt fate!
Alan
To Fuel gauge question
