Need Help! Headlamps gone wacky
Old Aug 27, 2007 | 06:18 PM
Rich Millward's Avatar
Rich Millward
Default Need Help! Headlamps gone wacky
Just as the title says....my 2000 6 sp coupe has a problem with the headlamp controls.When I turn the headlamps on, only the passenger side comes up,the drivers side stays down. When I turn them off, the drivers side comes up and stays up,even when I turn the car off...the passenger side goes down as it should.
It appears as if the motor and linkage is OK, just the controls are wacked..the manual points out a relay, that might be going bad....
Has anyone had this problem before?
I would appreciate any help.
Thanks in advance.
Rich
Old Aug 27, 2007 | 06:58 PM
Oldvetter's Avatar
Oldvetter
Use the manual over ride (****) to synchronize the headlights. Post if this fixes it.
You could also have a gear problem and/or drivers side bumper problems.
