You just have to remove everything from the front of the engine and drop the front suspension down a little bit.
The ony thing you need to drop is lowering the front cradle to make it easier to remove the steering rack. Nothing on the front suspension needs to be moved.
I thought so.I bought Will Handzel's book "How to Build High Performance LS1's" and He said it's alot easier or He recommends taking the whole drivetrian out. I thought that was insane.I couldn't believe Chevy would do such an Insane thing. They even give step by step Instructions for taking it out as a whole.
Sorry, I meant the steering rack. I should know better, I have done it.
I did a hds/cam change myself in m garage at home--It was really pretty easy-- Just take your time I used the instrctions from this site--They were wondeful and the picture are excellent-- http://ls1howto.com
