cruise control help !!
Old Aug 28, 2007 | 06:38 PM
flexbase's Avatar
flexbase
Navigator
Default cruise control help !!
My cruise control suddenly stopped working completely nothing shows up in the DIC when I switch it on It should say cruise control on . No codes , no blown fuses played with the switch nothing any ideas ? Car is a coupe automatic Thanks
01 c5 vette
Old Aug 29, 2007 | 02:01 AM
white90conv's Avatar
white90conv
Mine had a broken wire in the on/off circuit in the multifunction switch. This means there is no power to the cruise control circuts. Replaced the switch for about $120 plus my time (about 2 hours).
Old Aug 29, 2007 | 11:27 AM
jzhawk's Avatar
jzhawk
I have the same problem. I just dicovered it did'nt work on a road trip last weekend. It was fine last time I used it?
Old Aug 29, 2007 | 01:53 PM
mowton's Avatar
mowton
Not to Hijack the thread, but mine shows the "cruise set XX MPH" for a second or two and then goes to "Cruise Disengaged". Some times (Randomly) when I push the activation button, nothing happens as well?
System sensors were checked using a Tech II and all seem OK, they are leaning towards a computer issue? Which one?
Old Aug 29, 2007 | 06:46 PM
jakestyr's Avatar
jakestyr
same thing for me 2000 A4 -- I just adjusted the micro switch on the brake pedal -- problem solved
Old Aug 30, 2007 | 05:42 PM
flexbase's Avatar
flexbase
Navigator
Default Fixed it
Whoo ho ! it was the micro switch , it needed to be pushed in further thanx guys.
Old Sep 8, 2007 | 06:28 PM
1320video's Avatar
1320video
I'm having this same problem but both microswitches are functioning properly, in the data scanner it says cruise is on!
To cruise control help !!
