Active Handling Question---Upgradeable?//
Old Nov 7, 2001 | 08:57 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Default Active Handling Question---Upgradeable?//
Would it be possible to reprogram the cpu in a 99-00 to the 01 Active handling specs? If its all cpu controlled this should be possible right? Has anyone thought of or tried this? :confused: :D :cool:
Old Nov 7, 2001 | 09:19 PM
ZAP's Avatar
ZAP
Default Re: Active Handling Question---Upgradeable?// (SurfnSun)
I asked the same ? awhile ago and i was told it would not work. :cheers:
Old Nov 7, 2001 | 10:55 PM
Colorado's Avatar
Colorado
Default Re: Active Handling Question---Upgradeable?// (ZAP)
Just curious, why wouldn't it work?
Old Nov 7, 2001 | 11:35 PM
AF-Vette's Avatar
AF-Vette
I asked the same question quite a while ago and a dealer tech said it wouldn't work because the Active Handling program is tied to the VIN #. I suppose if you got someone's VIN from a 2001 or newer and had a cooperative tech you could do it ;). If C5-TECH is out there maybe he can clear this up. I also wonder if some of the PCM programmers could help us out with this?
Old Nov 8, 2001 | 03:46 AM
Mike Schriber's Avatar
Mike Schriber
It won't work because the hardware is different.
Mike :flag
To Active Handling Question---Upgradeable?//
