Help*****air Pump Diagram*****
Old Aug 30, 2007 | 04:39 PM
C5TORCHED's Avatar
C5TORCHED
Default Help*****air Pump Diagram*****
Putting front end back together. I think I have all the parts, I need but I need to connect the air pump with hoses and air box hose, not sure how. Help?
Old Aug 31, 2007 | 10:08 AM
C5TORCHED's Avatar
C5TORCHED
Default Help
Its a 98. Maybe I need to be more clear. The rubber hoses that come from the exhaust come together and run to the d/s front as a single "S" shaped hose--DOES THIS CONNECT TO THE AIR PUMP? Then the air box has a plastic nipple sticking out on the d/s-- DOES THIS GO TO THE AIR PUMP ALSO?????
Old Aug 31, 2007 | 11:01 AM
nastymant's Avatar
nastymant
the elbow from the airbox connects to the inlet of the AIR pump...outlet of AIR pump connects to exhaust manifolds...
Old Sep 1, 2007 | 10:42 AM
C5TORCHED's Avatar
C5TORCHED
Thank you thats what I needed.
Does anyone know where on the d/s the air pump gets mounted? To the front bumper or the front lower radiator cage?
To Help*****air Pump Diagram*****
