engine knock
Old Aug 30, 2007 | 09:56 PM
mithrander's Avatar
mithrander
Default engine knock
my 01 MN6 has a pretty good knock at WOT. I have borla catback and vararam intake. Any suggestions for fix
Old Aug 30, 2007 | 10:06 PM
orangejuice's Avatar
orangejuice
the engine knocks?? That ain't good, could be a broken piston, how is the oil pressure/ could be a rod bearing also. More details are needed
Old Aug 30, 2007 | 10:25 PM
rws.1's Avatar
rws.1
Mine did the same thing.
The Vararam leans out the engine.
Try higher octane gas
Try decabonizing the engine ( Seafoam or GM top engine cleaner)
Get a tune.
Old Aug 30, 2007 | 10:41 PM
orangejuice
pinging and knocking are different sounds, hope that is all he needs.
Old Aug 30, 2007 | 11:11 PM
DJMRTS's Avatar
DJMRTS
pinging and/or knocking will still make your knock sensors pull timing.
Old Aug 30, 2007 | 11:37 PM
TAZZVETTE's Avatar
TAZZVETTE
Try a 20oz. bottle of CHEVRON Techron Concentrate Plus...Works for me
Old Aug 31, 2007 | 01:11 AM
Van5150's Avatar
Van5150
Catch Can ?
Old Aug 31, 2007 | 03:00 AM
imiuru's Avatar
imiuru
I have experienced the same thing in third above 5k at wot and in 4th above 4.5k wot, It is a little predetonation. I was thinking I needed the tune......at higher speeds it must be stuffing a little more air
maybe its just the cooler coastal air
Old Aug 31, 2007 | 09:48 AM
gpracer1's Avatar
gpracer1
My 01 did the same. Got a handheld tuner and tuned it for more fuel above 4K rpms.
To engine knock
