Spar Plug Gap
Old Nov 8, 2001 | 12:01 PM
Bruce B.'s Avatar
Bruce B.
Default Spar Plug Gap
Hey folks,
Well, I finally got my wire and plugs in. I have the TR-6 plugs going in a stock '98 C5. WHat gap should I go with? Many thanks!
BRuce B.
Old Nov 8, 2001 | 03:35 PM
C5 Hardtop's Avatar
C5 Hardtop
Default Re: Spar Plug Gap (Bruce B.)
Use TR55's as the TR6's are a "colder" plug used for NOS and FI applications. Gap the TR55's at .060
Joel
Old Nov 8, 2001 | 10:27 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Default Re: Spar Plug Gap (C5 Hardtop)
WHat is proper gap for Tr 66s For N20 100 shot on 98 LS1.
Nitrovette
Old Nov 8, 2001 | 10:36 PM
team-zr1's Avatar
team-zr1
The 55s were designed for a gap around 0.60
TR-6s were designed for a gap around 0.45
Do not gap a plug over _/+ .008 to what the designed for.
55s are for stock, the Tr-6s are one step colder, thus if your stock and
running not to lean, the colder plug is a negative. Use them if you want to run a bit richer.
.For about every 50 HP over stock gain, reduce gap by about 0.10 using a plug designed for that gap.
I use a gap of 38-40 with 475 HP at flywheel.
To Spar Plug Gap
