How much better?
Old Sep 2, 2007 | 11:20 AM
vincentjames501's Avatar
vincentjames501
Default How much better?
I'm sure this has been posted elsewhere. But just curious. How much better is the later 04' z06 suspension than the base c5's (a 99' to be exact)? Can this swap be done? Or are they not compatible? Has anyone done this? Experiences? I really just want to know everything about them because I'm really contemplating buying the later z06 suspension.
Thanks in advance
Old Sep 2, 2007 | 03:54 PM
vincentjames501
anybody?
Old Sep 2, 2007 | 08:00 PM
Oldvetter's Avatar
Oldvetter
If you track it and/or do autocrosses, it is better. A lot of people have put on swaybars and shocks, some even switched springs.
IMHO, for a street car it is not worth it, as you rarely use it's handling capability now with the base suspension. Plus, it does ride rougher.
But to each his own. The swaybars flatten corners with a minimum of ride reduction. Easy switch too.
Old Sep 2, 2007 | 08:07 PM
Darion's Avatar
Darion
I had the base setup on my 2004 coupe and changed it out with Bilstien Sport shocks, Hotchkis sways and Z06 springs. Now, I know you are looking at Z06 setup and I went a little different direction but the change is dramatic from the base setup. First ride out I couldn't get over how much more controlled the car felt. No more plowing the front end in turns, floating over the road and higher speeds are much more stable. On the other end the ride is much more stiff but I don't feel it is too stiff, just feels like a sports car on a tight handling suspension. Also, you can do this swap, I did, in my garage on jack stands with hand tools, air gun would have been nice though. BTW, I'm no mechanic by any means.
Not exactly what you were looking for but I hope it helps ya out a bit,
Darion
Old Sep 2, 2007 | 08:33 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Check out the C5 section here and you'll see the suspension change out stuff!
http://www.ls1howto.com/index.php?category=0
Fairly simple and you can do it yourself!
Thanks,matt
Old Sep 2, 2007 | 09:27 PM
vincentjames501
Awsome. Thanks for the posts. So If I got the sway bars, shocks, and springs for 400 would it be worth it in your opinion if I install myself? My car has 65000 miles on it and these springs have like 5k. I just want a more controlled feeling.
Old Sep 2, 2007 | 11:30 PM
Oldvetter's Avatar
Oldvetter
$400 sounds like a great price. Not sure if you can change springs yourself?
Old Sep 3, 2007 | 11:10 AM
vincentjames501
naturally thats why I'm considering it. It could only make things better right? I'd love to learn how to install this stuff myself but kinda scared. It doesn't look that hard though. I'm only truly scared about engine mods.
Old Sep 3, 2007 | 08:52 PM
vincentjames501
Ok so final question. If I can get 02 z06 shocks, sway bars, and springs for 400 + shipping should I do it for the difference? Hopefully i get a response to this.
Old Sep 3, 2007 | 09:04 PM
bcseitz's Avatar
bcseitz
That is a good price for that package.
Heck Yes you will notice and love the difference!
My car had base suspension too. The only difference is I went with Bilstein shocks cause they work well with lowered cars. With the Z06 shocks you with get that "bounce" in the rear (if your car is too low)because the shocks don't like to work at a compressed state like the shorter Bilsteins do. The Bilsteins can always be added later if you want to go lower with your car.
Yes you can change the springs youself with some basic tools and a little mechanical apptitude. LS1howto.com has good instructions to assist you in your endevor.
Bob
Old Sep 3, 2007 | 09:11 PM
Uncle John's Avatar
Uncle John
Well, you mention an 04 z06 in your first post and an 03 z06 in a later post. The shocks were different in these two model years with the 04 shocks being superior in every respect. With that said, new Z06 sways, bushings and end links go for about $280 as a package.(somebody will correct me). Shocks are about $400 a set and springs go for God knows what. Please do yourself a favor and buy this setup if you can. You'll be really happy later on.
Old Sep 3, 2007 | 10:04 PM
vincentjames501
All right. Thanks for the advice. It's all from an 02 so sorry for the misleading information. I'm definitely going to buy them!
Old Sep 3, 2007 | 10:09 PM
Uncle John's Avatar
Uncle John
Very smart. PM me if you have any installation questions.
Old Sep 3, 2007 | 10:14 PM
vincentjames501
Always a good feeling to know you have support from people who are smarter than myself . Thank you!
Old Sep 3, 2007 | 10:38 PM
Uncle John's Avatar
Uncle John
I get it
Old Sep 4, 2007 | 11:38 AM
HeadHunter1's Avatar
HeadHunter1
Another option would be the Pfadt Coilover setup. Brian_NS just got it installed at ECS, he indicated it was very streetable, but much more expensive than what you have referenced. I think the coilovers are like $1800 and the sway bar is not cheap either. Just another option.
Old Sep 4, 2007 | 04:13 PM
ILM-Express's Avatar
ILM-Express
MFIC
If your not buying it for that price someone else will. That is a steal !
To How much better?
