Engine immediately turned off.
Old Sep 2, 2007 | 12:27 PM
rjensen3's Avatar
rjensen3
From: San Diego, CA, Point Loma-Home to the USN & USMC. GOD BLESS OUR TROOPS.
Default Engine immediately turned off.
Hi, Everyone!
Last night I started my vette and it immediately turned off. Not stalled out, but turned off. I have never had this happen and was wondering if the fact that it was an unusually hot day here and I had put about 50 miles on my vette had anything to do with this. Definitely seems to have been an electrical glitch, but don't know for sure. I restarted it and everything was fine, but thought I'd check with you guys, since you all know so much more than I do.
Thanks in advance.
RJ
p.s. Hey, what's with these ads that have shown up on my thread?? : (
Old Sep 2, 2007 | 03:14 PM
87SAM's Avatar
87SAM
Did you have the car in gear and start to move when it "turned off"?
Old Sep 2, 2007 | 03:34 PM
rjensen3's Avatar
rjensen3
Thanks for the reply!
No, it was in park.
Old Sep 2, 2007 | 07:15 PM
TnT9's Avatar
TnT9
Check the codes stored in the DIC and post what you find.
Also, try starting the car again and then wiggling the ignition switch. I suspect the switch may be going bad.
Old Sep 3, 2007 | 11:01 AM
rjensen3's Avatar
rjensen3
Will do.
Thanks so much!
Old Sep 3, 2007 | 11:32 AM
rjensen3's Avatar
rjensen3
TNT9 -
Thanks for your suggestion. I scrolled through and this is what the DIC displayed:
60 - IPC 1 code
99HVAC 1 code
All others showed no codes. I didn't see a way to further display what
"1 code" stands for and will appreciate any and all advice.
Thanks in advance.
RJ
Old Sep 3, 2007 | 11:40 AM
Bob Chapman's Avatar
Bob Chapman
If your ignition is fully on and you turn it off and then start the engine in less than 10 seconds it will shut off and you will get a message on your DIC that says something like "wait 10 seconds". After the 10 second wait it will start and run. It's related to the recycle time for computers.
Old Sep 3, 2007 | 11:45 AM
Mike Mercury's Avatar
Mike Mercury
the "wait 10 seconds" has to do with the Vats system not able to read the security pellet in the key; or the detection that the column lock motor didn't fully pull away from the lock plate.
My 2002 A4 does not have the column lock mechanism... I can put the key in and start instantly without issue.
Old Sep 3, 2007 | 12:19 PM
rjensen3's Avatar
rjensen3
Thanks for this interesting explanation; unfortunately, I did not turn off my engine, it immediately turned off on its own.
Any ideas what it means when it says "1 Code"? I plan on checking out my manual when I get a moment.
Thanks again for your input.
Old Sep 3, 2007 | 12:39 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Sounds like you're referrring to the Manual Diagostics readout. If you allow the DIC to automatically cycle through, it will display the actual codes themselves (which is a heck of a lot more useful than simply knowing there is "1 code")! Each code will be displayed for 3 seconds so you may need to repeat the process a couple of times in order to read (and write down) the codes.
Old Sep 3, 2007 | 01:52 PM
rjensen3's Avatar
rjensen3
Thanks! I will give that a try.
And thanks again for taking the time to reply.
Take care. Stay safe.
Old Sep 3, 2007 | 04:13 PM
rjensen3's Avatar
rjensen3
I found the information on the web, but thanks to everyone for their advice and suggestions.
RJ
60 - IPC B0516 U1160 H
(yes, now it shows 2 codes)
99HVAC B0367
I am going to do a search on the Internet for diagnostic codes, but was wondering if anyone else knows what these codes mean.
Thanks in advance.
Old Sep 3, 2007 | 08:12 PM
Bob Chapman
I see that Bill Curlee responded to your later post - Bill is REALLY good with electrical and other issues. Try what he recommends.
Old Sep 3, 2007 | 10:12 PM
rjensen3's Avatar
rjensen3
Yes, obviously, Bill is extremely knowledgeable and very generous to share his time and expertise. I will probably take my vette to the dealership, because I believe this is covered by the GMPP.
My thanks to you, too, for taking the time to read my thread.
To Engine immediately turned off.
