06 Z06 diff. in 99 C5?
Old Sep 2, 2007 | 08:45 PM
elwoodb's Avatar
elwoodb
Cruising
Default 06 Z06 diff. in 99 C5?
Name says it all, guys. will it fit? Got the numbers off it...
M6 Zo6 into a A4 C5.....???????
And if not, what years will bolt in...
Old Sep 2, 2007 | 08:49 PM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
Not sure, but the c5 case is stronger so what's the point? Get a c5 z06 3.42 differential and a hardened driver's side shaft.
Old Sep 2, 2007 | 08:51 PM
_Will_'s Avatar
_Will_
I just bought a 3.42 w/ hardened shaft from RPM along with a built transmission for a FANTASTIC price. You should call RPM on Tuesday.
Sending you a private message.
Old Sep 2, 2007 | 08:53 PM
chriswtx's Avatar
chriswtx
The C5 has a stronger rear end than the 06' Z06...Just beef up the Cf diff...
Old Sep 2, 2007 | 09:02 PM
_Will_'s Avatar
_Will_
Plus, with RPM they can install other gear sets.
I believe they do 3.15, 3.42, 3.73, 3.90, 4.10, but not totally sure if they do all those ratios. They do more than just 3.42 so you can choose the gear set right for your goals.
Old Sep 2, 2007 | 10:32 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
Besides,I don't think they are interchangeable
Old Sep 3, 2007 | 12:08 AM
Mike Mercury's Avatar
Mike Mercury
they are not
there were enough case alterations made with the C6 carrier to where they can't be inter-changed with the C5.
Old Sep 3, 2007 | 06:36 AM
elwoodb's Avatar
elwoodb
Cruising
Thanks, everyone. Now, if I get my carrier, any idea on where the heck in MA ,CT or anyshere in the northeast I can find a corvette quality tuner??
Thanks!
Old Sep 3, 2007 | 03:20 PM
02MillenniumVette's Avatar
02MillenniumVette
Thanks!
You might have better luck asking that in the regional section.
Old Sep 3, 2007 | 08:21 PM
Dave concrete's Avatar
Dave concrete
Thanks!
ECS New Jersey or just order a DTE they will swap with you and have a good local tranny shop do it
To 06 Z06 diff. in 99 C5?
