Removing Rear rotors
Old Sep 3, 2007 | 09:22 PM
notnuts16's Avatar
notnuts16
Default Removing Rear rotors
I am having a problem removing the rear rotor on my 04. It has 24,000 miiles and I want to paint the rotors. I can only get the rotor to come out about 1/2". The e-brake is off. It then wants to spring back in to the hub. Any ideas?
Old Sep 3, 2007 | 09:25 PM
brookman's Avatar
brookman
have you removed the caliper and the bracket? if so - whack it with a rubber mallet and it will push past the rust keeping it on.
Old Sep 3, 2007 | 09:49 PM
notnuts16's Avatar
notnuts16
Default Rear brake rotors
Caliper and bracket is off. I have tapped the rotor and I can get it to come out but it won't release from the e-brake or at least thats what I think it is.
Old Sep 3, 2007 | 09:53 PM
Uncle John's Avatar
Uncle John
If it comes out 1/2 inch and then "springs back", your rotor is most likely hung on the e-brake pads. Rotor has a slight groove worn on its inside and the pads are hanging on that. Don't know of any good way to resolve this. Maybe someone else can chime in.
Old Sep 3, 2007 | 11:10 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
There are two 15 mm bolts on the back side of backing plate the hold the shoe assembly in place and the parking cable brake.
Try removing them.
Old Sep 4, 2007 | 07:18 AM
notnuts16's Avatar
notnuts16
Default Removing rear rotors
Thanks for all the suggestions. I will try again soon.
Old Sep 4, 2007 | 07:27 AM
dogboy's Avatar
dogboy
I just went through the same thing. Keep working at them with the aid of a large screwdriver. I was able to get one side off by prying down on the back of the E brake shoe and it popped off. The other side took the shoe off with the rotor. I had to fiddle with the E brake spring for a 1/2 hr trying to get it back in place before putting on the new rotors. PIA but not to bad.
Old Sep 4, 2007 | 07:55 PM
Nick1's Avatar
Nick1
True, don't panic if the spring pops off. You have to finess it back on. I used an old screw driver with a notch ground in the end to help.
Old Sep 4, 2007 | 08:43 PM
notnuts16's Avatar
notnuts16
Thanks for all the ideas. This forum is all most better than sex.
Old Sep 4, 2007 | 11:09 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Wadda ya mean almost. Here you don't have to beg for it
Old Sep 5, 2007 | 02:03 AM
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
We also don't need to cuddle nor do we expect anything less than the truth when we ask if our butts look big.
Old Sep 5, 2007 | 07:33 AM
rws.1's Avatar
rws.1
make sure as you start getting the rear rotor to move that you keep it as square a possible, that helps it get by the parking brake shoes.
While it is off. adjust the parking brakes so they just fit ( rotating the brass colored star wheel) that way your parking brakes will catch and hold with the lever at a 45 degree angle
To Removing Rear rotors
