Anti Abuse limiter
Old Sep 6, 2007 | 11:13 AM
zoomz's Avatar
zoomz
Originally Posted by BlackZ06
(depending on your point of view you have an increased risk of driveline failure, and the vehicle may feel more "harsh" under heavy throttle shifting.
When he says "driveline failure" , that really means , now you have power and can really raise hell with the car .
Adjusting or turning off TM is not going to cause a failure , your new found ability to put the power to the ground and rock and roll will
Old Sep 6, 2007 | 04:31 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Originally Posted by Kamil D.
i have a 97 a4 will the same apply?? What would be the best and the least expensive way to change it??
Handheld tuners or a good dyno tuner.
Old May 23, 2008 | 10:58 AM
JOEY P's Avatar
JOEY P
Will a handheld programmer like a hypertech programmer turn off torque managment or can it only be done by a tuner??????
Old May 23, 2008 | 01:40 PM
Mike Mercury's Avatar
Mike Mercury
there is an abuse mode (which is different that TC or AH. Although there's code in the PCM for the Abuse Mode, I've never known a person to meet all the parameters necessary for that to be engaged.
And actually is's not for "abuse", but more from too hot operating temps - or oil temps too high. It's more a "self-preservation" mode than an abuse mode.
A 2000 auto also has a 70% wot setting from the factory , that will also be address by the tuner .
Old May 23, 2008 | 07:09 PM
Mike Mercury
Originally Posted by JOEY P
Will a handheld programmer like a hypertech turn will it off torque managment
it's supposed to. The Diablosport Predator certainly will.
Old May 23, 2008 | 07:27 PM
itzza427's Avatar
itzza427
This is the first I've ever heard (usually hang out in general) of the 70% wot on autos. I have an M6 do they get 100% ??
Old May 23, 2008 | 08:08 PM
C5Pat's Avatar
C5Pat
Let me tell you what happened to me the other day, first of all I have a 02 a4 Corsa Catbacks BPP air induction 3:42's and a Predator HP tune. the only other thing I did with the predator after the tune was increase the shift pressures 5%.I took off from a stop in 3rd at about 70% throttle.it hit second gear, the back end broke loose, crossed centre line, scared the sh-t out of me for a second then I could't stop smiling!! Moral of the story be careful what you wish for, you don't need to scew with TM.
Old May 23, 2008 | 09:19 PM
JOEY P's Avatar
JOEY P
This doesnt make cents why would you take off from a stop in 3rd and then go to second with an a4 automatic transmission ????????
Old May 24, 2008 | 08:45 AM
C5Pat's Avatar
C5Pat
The shifter was in 3rd. The transmission still starts in 1st goes to 2nd then 3rd and so on. When it shifted from 1st to 2nd thats when it got exciting
Old May 24, 2008 | 10:14 AM
99 vett babycar's Avatar
99 vett babycar
the trani in a C5 is the weakest link in the drive train.GM put TM in to "protect" the trani since its not designed to handle all the torque the engine can generate.The torque management tables can be adjusted to increase the % of torque delivered to the rear wheels. Its not a good idea to totally disable torque management unless you'd like to get to know the guys at RM transmissions.
Old May 24, 2008 | 10:59 AM
mvvette97's Avatar
mvvette97
If you only has efi live I could change all that stuff for ya and send you the tune over email. I didn't delete the torque management but did reduce it. I done alot of other small things also on mine. seemed to help alot.
Old May 24, 2008 | 02:26 PM
lionelhutz's Avatar
lionelhutz
Yup, tranny is based on the 700R4. They never were a very strong tranny. The toque management is to protect from breaking the transmission from the shock of a hard shift. the tranny may be good for about 400ft-lb of torque. The shock load during shifting could generate much higher peak levels even though the engine is not producing that much.
Also, as stated, it's not an on-off thing. The level of TM can be adjusted via a set of parameters. If you put in a heavier built tranny you could tune out say 75% of the TM.
Peter
Old May 25, 2008 | 09:28 AM
  #33
JOEY P's Avatar
JOEY P
Why would gm put a tranny in that would not handle the motor......I will never understand why they did alot of the things that they did...
Old May 25, 2008 | 01:11 PM
  #34
lionelhutz's Avatar
lionelhutz
I'd guess it's because it was the only reasonable tranny they had. They could have gone 4L80E but it was likely deemed to be too heavy. Of course, the 4L60E was likely figured to be OK with the first LS1 and then was designed into the C5. It's likely one of the main reasons why there was a new 6-speed auto transmission for the LS2/LS3 once the C6 came out and along with that new tranny came more power.
Peter
Old May 25, 2008 | 08:11 PM
  #35
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
The trans in the Vette will handle the motor just fime. Look how many C5's have over 100,000 miles on them with no trans trouble, It is when you start over powering the motor that you have troubles, That is why there are high performance trans and diff parts. Almost all newer cars have TM or AM built in the computer, It isn't just GM.
Old May 25, 2008 | 09:22 PM
  #36
71vetteinva's Avatar
71vetteinva
Can you increase shift pressure (line pressure) and still keep the stock torque management settings in place?
I've always been taught that a shift kit actually prolonged the life an automatic transmission. That is, soft shifts build up excess heat. Perhaps it's only the case if the automatic transmission is capable of handling the shock in the first place?
I'd was thinking about purchasing a Predator just to firm up the shifts. If the 'vette can't handle it, then I guess I'll just keep my money.
