Replaced oil pressure sensor... broken again
Old Sep 7, 2007 | 12:31 PM
lopan's Avatar
lopan
Default Replaced oil pressure sensor... broken again
I replaced my oil pressure sensor last night and it worked right away after I got everything put back together. Then when i started it up this morning, it's broken again. Did I screw up the install, or could it be something else screwed up?
Old Sep 7, 2007 | 12:39 PM
Javier@DIDRACE.COM's Avatar
Javier@DIDRACE.COM
was it the aluminum housing one? i use the buick oil pressure sensor with no probs so far.
Old Sep 7, 2007 | 01:47 PM
jovette's Avatar
jovette
I've seen several members suggest three things:
1) purchase new sensor from NAPA
2) make absolutely certain that all electrical connections are COMPLETELY free of any oil residue.....clean, then clean again and blow dry before installation of new sensor.
3) make certain that the new sensor is NOT over torqued. recommended torque is 15 ft. lbs., I believe, so make certain you are using an accurate torque wrench, and if in doubt, get a good one. may even consider torque to 13 or 14 ft. lbs.
Old Sep 7, 2007 | 03:38 PM
timemender's Avatar
timemender
Excellent advice.
Old Sep 7, 2007 | 07:05 PM
Slick Rick's Avatar
Slick Rick
The one from Napa is made in mexico also. Its steel not brass....... I just checked today. The way I see it dosnt matter who you buy it from its a crap shoot. Some guys change em and there fine and somtimes there not. Im getting mine replaced tomarrow, The one in there now lasted about 3 months. Seems so far that the relocation thing works out the best. Thats probably where Ill go next if the one installed tomarrow takes a dump......
Old Sep 7, 2007 | 08:31 PM
lopan's Avatar
lopan
I ended up making an appointment at the local dealership to get it replaced. It's only $97 for the labor and since i originally bought the part with them it's under warranty. I figure, this way if it breaks again they will fix it for free since they warranty their work for a year.
Old Sep 7, 2007 | 09:27 PM
CTSV OWNER's Avatar
CTSV OWNER
Funny thing is it's the same senor in a SSR and other GM products and you don't hear anyone else in large numbers replacing them. I wonder why they fail in Vettes and not the others.
Dave
Old Sep 8, 2007 | 12:22 AM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
http://forums.corvetteforum.com/show....php?t=1588172
Start reading. Several solutions here.
Clayton from Las Vegas
Old Sep 8, 2007 | 10:29 AM
rws.1's Avatar
rws.1
I bought the GM replacement.
Cleaned the terminals to ensure no oil residue
Torqued to 15 ft-lbs
8K + miles later all is still well....
Old Sep 8, 2007 | 11:44 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
GM is will warrant the part for 12 months. Return it to them and get a new one for free! It also helps to serve notice to GM that they are providing bad parts.
To Replaced oil pressure sensor... broken again
