Do bump steer kits really work?
Old Sep 7, 2007 | 09:07 PM
spiral04's Avatar
spiral04
Default Do bump steer kits really work?
The one thing I hate about the vette is when it hits a bump and jars the car to the side. I know coilovers would fix the problem, but that's not in my budget right now. Do the bump steer kits work? Are any brands better than the other? Thanks for any help. Oh yeah, my car is lowered a tad on stock bolts.
Old Sep 7, 2007 | 10:16 PM
Robls6's Avatar
Robls6
Coilovers won't fix bumpsteer in themselves. A transverse leaf spring doesn't care what the other side is doing as the spring is tied in the middle to the car's crossmember. Each side acts "independently" of each other hence the name "independent suspension".
Old Sep 8, 2007 | 02:14 AM
spiral04's Avatar
spiral04
So, do you know if the bumpsteer kits work? Anybody?
Old Sep 8, 2007 | 01:47 PM
bcseitz's Avatar
bcseitz
When we first bought our car Z06 sways were one of the first mods. They really helped in keeping the car flat in the corners but made the car leap and hop sideways even more when hitting the Feeeway overpass expansion joints. I had the Baer anti-bumpsteer tie rod ends installed to try to eliminate the same issue. They seemed to help...a little.
What helped even more was when I added new Z06 springs and Bilstein sport shocks.
But the most noticable change in how the car acted on those high speed turns with expansion joints was to get rid of those stock GoodYear runflats. I think the extra super stiff sidewalls of the runflats installed on an already stiff performance suspension was a lot of the problem. I had Michlein Pilot Sports (non runflats) installed and made our car feel like new.
Back to the Baer antibump steer tie rod ends. They wore out in 6000 miles. I put the stock tie rod ends back on and had the car realligned again. I liked the way they (the Baers) felt but they aren't cheep and they wear out to fast. Forum members pointed out to me that there are better/stronger adjustable tie rod ends out there but they aren't cheep either. The stock one's work fine.
For me the new tires made the most difference in helping to keep the bumpsteer under control.
Bob
Old Sep 8, 2007 | 02:42 PM
DBL001's Avatar
DBL001
the 07 Z06 shocks did it for me, no more skipping
Old Sep 8, 2007 | 04:53 PM
spiral04's Avatar
spiral04
Thanks. My car is an 04 with 20k miles. The ride is good on the car, it's just the bump steer. I have Pirelli P-Zeros with Z06 sways, but stock shocks. I hate to spend alot of money on the shocks only to find that didn't help either.
Old Sep 9, 2007 | 04:57 PM
bcseitz's Avatar
bcseitz
Stock shocks, with Z06 sways but with stock tires was when my car was at it's worst.
Old Sep 9, 2007 | 05:15 PM
spiral04's Avatar
spiral04
I have to see what springs came with my car, so you think in my case, shocks and springs would do the trick??
Old Sep 9, 2007 | 06:14 PM
bcseitz's Avatar
bcseitz
Through experience with my car, adding one component(s) at a time, sways, then shocks, then springs and finally tires, I found that the suspension worked better as a complete package.
You can always do what DBL001 suggested. Try just the shocks for a while and see what you think. If you feel it's still not what you would expect you can always upgrade to springs later. The springs are the most expensive, around $900. w/shipping for new ones.
Can you find someone with a Z that you might be able to ride with so you can get a feel for the ride and handling?
I really love the Z suspension under my car. No regrets at all. BUT please do a lot of research on this subject before you spend a lot of money and find that you don't care for the changes.
GM did a lot of testing on the Z06 to get it to be one of the best sports cars on the road. I'm sure they felt that their suspension for the Z is the best possible combination of components for a street/track sports car.
Old Sep 9, 2007 | 08:47 PM
spiral04's Avatar
spiral04
Thanks! I'll look around. For the money for Z06 springs and shocks, I could get coilovers.
Old Sep 11, 2007 | 12:20 AM
striper's Avatar
striper
Get yourself a good set of shocks, such as the Bilstein Sports and a good alignment. That should take care of the problem. You don't need to change the tie rod ends.
Old Sep 11, 2007 | 04:49 AM
HotrodZ06's Avatar
HotrodZ06
The purpose of anti-bump steer tie rods is to bring your tie rod in correct geometry with the spindle after you have lowered your car beyond that recommended by GM (stock bolts). If your car is near stock height or only lowered on the stock bolts, installing anti-bump steer tie rods could have a negative effect on your steering, probably inducing some bump steer. Think of the anti-bump steer tie rods as a way to lower the outer ends of tie rods so they return to a near parallel position (as designed by GM) after the steering rack has been lowered to the point that the outer ends of the tie rods would be angled upwards.
Rod
Old Sep 11, 2007 | 07:38 PM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
Originally Posted by HotrodZ06
The purpose of anti-bump steer tie rods is to bring your tie rod in correct geometry with the spindle after you have lowered your car beyond that recommended by GM (stock bolts). If your car is near stock height or only lowered on the stock bolts, installing anti-bump steer tie rods could have a negative effect on your steering, probably inducing some bump steer. Think of the anti-bump steer tie rods as a way to lower the outer ends of tie rods so they return to a near parallel position (as designed by GM) after the steering rack has been lowered to the point that the outer ends of the tire rods would be angled upwards.
Rod
Very well said.
I'm still curious about what bcseitz said concerning his tie rods wearing out after 6000 miles. This is the first time I've heard of this. If this is true, then it really doesn't pay to do this mod as I drive about 10k miles a year. I'm wondering if he might have had a defective set. Anyone else hear of this problem with the tie rod kits??
Old Sep 11, 2007 | 09:26 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Rod
Thanks Rod for using the term correctly. Lauching a car off a bump has nothing to do with "bump steer"
Randy
Old Sep 11, 2007 | 09:28 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Originally Posted by Alex1217
Very well said.
Race cars wear out faster then street cars. Putting racecar parts on will always require more work and cash.
Randy
Old Sep 11, 2007 | 10:18 PM
DAYUIZ's Avatar
DAYUIZ
...then it really doesn't pay to do this mod as I drive about 10k miles a year.
I bought my car early March with 83,000 miles. Its mid September and I just rolled over 99,000 miles today. 17,000 miles in 6 months. I look at high mileage as a good reason to rebuild/improve!
-Steve
Old Sep 12, 2007 | 09:52 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
You will probably have more luck asking this question in the autocross/roadrace section.
Old Sep 12, 2007 | 10:57 AM
bcseitz's Avatar
bcseitz
Very well said.
I did a post on this a while back when I discovered that the ends were bad. Here is the link to that post. Got a few answers on the subject.
http://forums.corvetteforum.com/show...r+tie+rod+ends
To Do bump steer kits really work?
