Gauge Cluster Problem
Old Sep 7, 2007 | 09:39 PM
lfsglass's Avatar
lfsglass
Default Gauge Cluster Problem
I just purchased a '99 FRC and the gauge lights don't light up....everything else works fine. Dimmer turned up and I already changed the multifunction switch. All of the other lights work fine...interior lights, tailights, headlights, running lights, turn signal, radio, lock and window switches, etc...all work fine. Looking for an easy way of trouble shooting. Could it be a plug or a bulb? How can I get to it and where should I look? Thanks
All guages work, message center works fine, DIC buttons also light up, check engine, abs, trac control...all light up. Every thing lights except the gauge lights. Thanks again, Steve
Old Sep 8, 2007 | 12:34 AM
BATM4N's Avatar
BATM4N
You must have a loose wire. I just changed out my cluster to get HUD in my 98 and there are two lights, one on each side of the gauge cluster behind the buttons on the right and left(hud controls if you have a hud) I doubt both bulbs would go out at the same time.
