The weakest link?
I would like to run it at the track a hand full of times during the summer. But, I do NOT want to drive an hour to the track and then have to get a flat bed ride home! So, I'm wondering what you need to do to be able to run 450 rwhp with drag radials at a track w/o having to worry about something blowing up every time I launch it?
I've read that the left output shaft has a tendency to snap? If you upgrade the left should the right also be done or is it common to just do the left? Are there problems with the torque tube? What else give away in the drive line and in what order is it most likely to happen?
Also, I'm new and not all that familiar with the drive line setup on the C5's yet (haven't had anything torn apart yet), is there some good illustrations or resources on them?
So, what's needed to run 450rwhp with drag radials at the track and hook hard enough to pull 1.7 60s or better?
thanks
aero
1. Clutch
2. Left hand half shaft or output shaft?? Are these the same thing??
3. Rear diff. brace - 'DTE cage'
What else? At what point do you have to worry about the torque tube? what would be the next step or thing to worry about?
I love my Textralia OZ700. Sure wish I had done the shafts when I had the trans out. I still may go ahead and do it. I am well over 500 rwhp now on the bottle.
