TCS/ABS light
Old Sep 8, 2007 | 09:44 AM
AlexB333's Avatar
AlexB333
Default TCS/ABS light
Hey guys, I have read the threads on these codes and I need help. I just found yesterday my car had the dreaded battery leak. I pulled it out and it leaked all over the place! I cleaned all the wires, painted the frame again, put in red top optima battery
This morning I take the car out and WOT through 4th gear and then these codes come on.
Mine are different than the typical EBCM failure one of 1214.
I have the code TCS1233 and RFA 1064.
Loss of comm with the BCM and right front wheel sensor?
I wanted to change my fluids this weekend but now I have to figure this out.
I have never had any problems with my car throwing codes so I figured the battery leak might not have destroyed anything.
Would the battery leak be in the area of these codes.
I thought the battery usually caused problems with the PCM?
Could a bad EBCM cause these codes?
Is it just a coincidence that I changed my battery and cleaned those wires...i tend to think not but where do I start
Thanks for any help...now I am off to see PSU stomp Notre Dame. I probably wont even be able to enjoy myself now
Thanks, I don't know what I would without this forum
Old Sep 8, 2007 | 10:07 AM
jirasvet's Avatar
jirasvet
Could be a coincidence. I would read the sticky on electrical problems, since it is one wheel sensor you could actually have a bad wheel sensor, and the RFA not communicating to BCM Could be a bad connection,ground or fuse.
