Installed new Head Unit, car won't start! Help!
Old Sep 9, 2007 | 07:25 PM
indieaz's Avatar
indieaz
Default SOLVED: Installed new Head Unit, car won't start! Help!
Just installed a new head unit. I ran accesory power from yellow wire hanging lose behind kickpanel on passenger side. When i turn my key to "on" all my power accesories work (windows, locks, stereo)...however, i get *nothing* on the DIC display. If i turn the key to run my security light blinks and the car dings at me. I took my center console back off to make sure nothing was disconnected. All appears well. What could I have possibly done to cause this?
EDIT: Additionally my keyless entry is now not working. What is strange is i had the stereo all installed last night and the car started fine...i just hadn't reassembled the center console yet. I put all that back together today and now noticed this problem. Any help is *GREATLY* appreciated as i need to drive to work tomorrow :p
Old Sep 9, 2007 | 07:56 PM
zo6chik's Avatar
zo6chik
check ALL fuses, ive been there before
Old Sep 9, 2007 | 08:12 PM
indieaz's Avatar
indieaz
Just pulled all fuses inside and out...they all checkout fine
Old Sep 9, 2007 | 08:27 PM
JJEXP's Avatar
JJEXP
Step 1: Disconnect the yellow wire, as it is not an accessory wire
Step 2: Reconnect to orange wire at ignition harness
Step 3: Get your *** back to CZ28, the lounge is dead
Old Sep 9, 2007 | 08:31 PM
indieaz's Avatar
indieaz
Where is the ignition harness?
A guy in the audio sticky posted the yellow wire is accessory...it seems to power the radio fine at least. I'll disconnect it and see what happens.
Old Sep 9, 2007 | 08:33 PM
Pro Street's Avatar
Pro Street
Old Sep 9, 2007 | 08:40 PM
indieaz's Avatar
indieaz
OK, just realized a few new things.
1) With my radio plugged in (powered off that yellow wire), the security light does *NOT* blink...and no dinging. When I noticed that earlier was with the radio disconnected (one of my first troubleshooting steps was to unplug the wiring harness from the radio)
2) If i unplug the harness from the radio (which effectively disconnects the yellow wire) the security light will blink and ding will sound when i try to start it.
3) Either way...car won't start using or not using that yellow wire (this is the spare yellow that is simple cut & taped...so it was never connected to anything to begin with).
Old Sep 9, 2007 | 09:15 PM
indieaz's Avatar
indieaz
Battery is a tad old...so i tried jumping it. Same issue still.
Old Sep 9, 2007 | 09:36 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Check it for codes ???
http://www.corvettedoctor.com/Code_Main.html
Old Sep 9, 2007 | 09:38 PM
indieaz's Avatar
indieaz
I can't...the DIC is dead. The LCD is blank and none of hte buttons elicit a response...and I don't have a scanner. If it would start...i could bring it somewhere to get it scanned though
Old Sep 9, 2007 | 09:44 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It sounds like you have a battery cable problem. Have you checked all of your connections on the battery, starter, ground to make sure they are tight ?
Also chech IPC (Instrument Panel Cluster) fuse to that it works ? Do you have interior lights ?
More info please.
Old Sep 9, 2007 | 09:48 PM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
I know you said that you tried to jump the car, but my guess is still dead battery! While installing my stereo I drained my battery several times. These cars do strange things when presented with low voltage.
Old Sep 9, 2007 | 09:59 PM
indieaz's Avatar
indieaz
I have interior lights, they work fine. Power windows/locks/headlights/wipers all work fine.
I will try and test the battery tomorrow I suppose.
I have verified my battery terminal connections are solid..i've d/c'd and reconnected twice now.
It just seems strange that it worked fine...then i connected the stereo and bam it's broke.
I checked all my fuses adn they looked good...I"ll double check the IPC one.
Old Sep 9, 2007 | 10:02 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I would recheck fuses inside and out. It sounds like you blew a fuse.
Old Sep 9, 2007 | 10:12 PM
Roger G's Avatar
Roger G
Originally Posted by ajg1915
Wow! Loved the link! Thanks! I did not know how to do that without an external code reader!
Old Sep 9, 2007 | 11:05 PM
indieaz's Avatar
indieaz
I had checked fuses inside and out once already, i just went out and did it again. Fuses all look fine. I'm going to get the battery tested.
Old Sep 9, 2007 | 11:41 PM
indieaz's Avatar
indieaz
Battery tested good.
Any more ideas? I must have knocked a wire lose or something somewhere...but i didn't come in contact with very many.
EDIT: Additionally...during my install i discovered a Clifford alarm device (perimeter sensing unit). I have no fob or control device of sorts for this alarm. I wonder if the alarm thinks the car is being stolen? Possibly there's a kill switch somewhere? I know jack about alarms :-/
To Installed new Head Unit, car won't start! Help!
Old Sep 10, 2007 | 10:50 AM
indieaz's Avatar
indieaz
Well, i found what appears to be the "brain" for the alarm and disconnected it. Same symptoms still.
Old Sep 10, 2007 | 07:45 PM
indieaz's Avatar
indieaz
SOLVED! Apparently the Clifford alarm that was int he car (which I had no idea was there until i installed the HU this weekend) had been left in Valet mode since before i bought it. The previous owner didn't have any key fobs...and never mentioned there being an alarm (betting he didn't know either). At any rate...the alarm had gone out of valet mode. It's a clifford though which requires a PIN number to go in and out of valet mode. I don't have the PIN either. Ultimately i decided to just unhook the alarm system and reconnect the ignition and started positive wires bypassing the alarm. Now everything works fine and dandy.
So the problem wasn't my C5 at all...but a pile of crap alarm system. Good riddance!
Special thanks to Bill Curlee for his assistance on this one! What a guy to go out of his way and give me assistance on the phone!
Old Sep 10, 2007 | 07:50 PM
Pro Street's Avatar
Pro Street
Glad you found the problem!
