My 98 has power seats, both driver and passenger. The seats move forward, up and down fine however the lumbar support in both has stopped working. The motor? makes a noise when I push the switches but the seats, both, no longer "inflate/adjust". I have removed the passenger seat but can not find the problem. Any suggestions?
When you push the switch the other way, it releases the air in
the bladder by opening a valve. Any tiny obstruction in the valve
that keeps it open would cause your problem.
Otherwise, you have a leak in a hose, or the bladder.
Thanks!
Welcome to the club, this is a common issue and the problem is with the plastic inlet fittings that are attached to the bladders.They become brittle and break off. Remove the seat covers and you will see a main bladder and side bolster bladders with hoses to the pump. Replace the main bladder with a Core 360 manual bladder (remove the air bulb) and attach to seat hose.
Amazon has these for $39.95, you can also find smaller similar ones just search the internet if you wish to replace the bolster bladders. The dealer price for a factory replacement is over $500.00 just for the part!
I have issued a formal complaint to GM about the outrageous cost for this part.
OGC5
