U/D Pulley and stereo system question
Old Sep 10, 2007 | 02:16 AM
GKE's Avatar
GKE
Default U/D Pulley and stereo system question
Has anyone had problems if you have an aftermarket system with sub and amp and also an u/d pulley? I just want to make sure that if I install both I won't have alternator problems, or charging system problems. The u/d is 25%
Old Sep 10, 2007 | 09:19 AM
WKMCD's Avatar
WKMCD
I run an 800w sub amp and 2 100w amps - 1 for each door with no problems.
Old Sep 10, 2007 | 11:48 AM
GKE's Avatar
GKE
Are you running the same u/d specs, 25%?
Old Sep 10, 2007 | 12:15 PM
MattB's Avatar
MattB
I think Lingenfelter has a UD kit that has a new larger pulley for the alternator to keep it spinning at the same rpms.
Old Sep 10, 2007 | 09:22 PM
Brad@RevXtremeAutoSports's Avatar
Old Sep 11, 2007 | 03:39 AM
spiral04's Avatar
spiral04
I've had no problem with the asp 25% underdrive pulley with a 600w amp. See you at the Redline show.
Old Sep 11, 2007 | 06:52 AM
WKMCD's Avatar
WKMCD
Yupper. 1000w total and no problems. My alternator stays at 13.5 volts.
To U/D Pulley and stereo system question
