i was wondering if anyone else has had this problem.i start the car and start driving,after awhile;check gaugelight comes on.the monitor saye low fuel and the gauge indicates empty.what are your thoughts.thanks
Techron Plus is your friend. Lots of forum members have had this experience. Pour a bottle of Techron in the next few fill ups and then use gas with Techron (Chevron and Texaco) and see if the problem goes away. HTH
1. the fouled sensor that needs a fuel system cleaner and switch to top tier gas
2. a corroded ground connection
3. a faulty sending unit that needs replacement
