Temp read xxx
Old Sep 10, 2007 | 08:45 AM
procs2v's Avatar
procs2v
Default Temp read xxx
My car temp goes to 260 as soon as I turn the car on, and the dic reads xxx. The only thing I did different was new plugs. But I did try Ranger's fan trick the day before. I had no problems at all the whole day. Today I changed temp sensor and checked fuses. Nothing. I read a few post and tried to clear the codes. Now after I start the car it comes on about 15seconds later, at first it would come on immetiately.
Old Sep 10, 2007 | 09:28 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
xxx Porno Temperature
Old Sep 11, 2007 | 08:40 PM
procs2v's Avatar
procs2v
Here is a update. I replaced the temp sensor wishing it was bad, nothing. I check the connector and it was good. I had a friend set the codes with one of his tools from work. Nothing. He then reflashed my computer and it work. I thought all was good. Then today after work I get in the car and it cuts off. Then I restart it and the temp went to 260 again. Can someone please help.
Old Sep 11, 2007 | 08:48 PM
vetterlatethannever's Avatar
vetterlatethannever
[snicker]
Old Sep 11, 2007 | 09:00 PM
brucemoose2's Avatar
brucemoose2
Check the wiring from the temp sensor. Follow it to the PCM and look for somewhere it might be shorting out.
Old Sep 12, 2007 | 12:44 PM
procs2v's Avatar
procs2v
ttt
To Temp read xxx
