DIC Reading
Old Sep 10, 2007 | 06:49 PM
jazzvette's Avatar
jazzvette
Default DIC Reading
Is there anyway I can reset the reading I'm getting on my speedo? It says service traction control,abs and steering column. The lights are also on. Pleases help I find it very annoying.
Old Sep 10, 2007 | 10:00 PM
rws.1's Avatar
rws.1
you need to "pull the codes"
On the dash to the right of the speedometer you will find some buttons numbered 1 to 5 with a button labelled reset below them
with the key in the on position, but the engine not running
push and release the rest button
next push and release button #4
next push and release button #1 four times
THe car will start cycling thu a series of codes.
when it finishes it reurn to the first code.
write it down as well write whether it has an H or C after it
you then can use the #2 and #3 buttons to scroll up and down thru the codes list.
write down all the codes displayed and
post them here.
When you are satisfied you have all the codes written down, you can go to each code, push and hold the reset button for 1-2 seconds and each individual code will be erased.
That will help us identify what is causing your DIC warnings
