Do I Need Larger Injector Size?
Old Sep 11, 2007 | 10:43 PM
chevybob's Avatar
chevybob
Default Do I Need Larger Injector Size?
Hi,
I have a 1998 mn6 with the stock injectors. The car has a mild cam, headers and 90/90 setup with many bolt ons ( 390rwhp ). I just installed AFR 205 heads 59cc. Need to get a new power tune but unsure about increasing injector size? Any thoughts?
thanks
Old Sep 12, 2007 | 12:05 AM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by chevybob
Hi,
thanks
I'm saying yes. Your stockers are probably operating near the upper limit of their duty cycle as is.
Old Sep 12, 2007 | 12:16 AM
Higgs Boson's Avatar
Higgs Boson
My Z06 29 lbers were good to about 490 RWHP. I installed some 37s. Want to buy my 29s?
Old Sep 12, 2007 | 12:18 AM
GKE's Avatar
GKE
I am actually curious about this as well. I am doing similar upgrades as you chevybob but I will also be adding a 100 shot nitrous. I was looking at some used 42lb in the parts forum, would those be too big?
Old Sep 12, 2007 | 12:34 AM
Higgs Boson
Too big.
Old Sep 12, 2007 | 12:51 AM
CraZee ZO6's Avatar
CraZee ZO6
Yea Im maxed out but still ok on my stock injectors. 29lbs. On the verge though.
Old Sep 12, 2007 | 10:00 AM
Gordy M's Avatar
Gordy M
Find a friend with a full feature scanner and run a 15-20 minute log to find duty cycle and performance characteristics of your car. From the scan they or a tuner can either recommend keep the current injectors or get larger and what size you need. Also, this is the info the tuner would need to give you the intermediate values in your final tune. By the way in that 15-20 minute scan you will have to sacrifice some gas in doing some all out runs thru the gears.
Old Sep 12, 2007 | 12:50 PM
Billdog350's Avatar
Billdog350
before you go spending money, see what your tuner says. Stock injectors are usually good for ~400rwhp...and SVO 30's for at least 450-500rwhp. Some people go too big (I went to #42) and then have trouble tuning.
Old Sep 14, 2007 | 01:29 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I have a 98 with 390 RWHP and on the data logger the duty cycles will shoot up to around 88% they say 80% is about the limit--or they will overheat-98's came stock with 28 lb. injectors--If I were racing a lot or running at WOT alot I should change them to at least 30 lbs. However for intermitant short use they should be fine and I haven't had any issues
PS I would make sure you have adequate fuel pressure and flow--AND make sure your voltage is consistant at the fuel pump--
Old Sep 14, 2007 | 01:35 AM
tblu92's Avatar
tblu92
Only if you will be using a DRY nitrous system the injectors will need to be addrerssed--On a WET system additional fuel is added in the nitrous nozzle and mixed with the NOS
Old Sep 14, 2007 | 06:49 AM
99 vett babycar's Avatar
99 vett babycar
you're fine
Old Sep 14, 2007 | 08:08 AM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
You WILL need new injectors if you are running heads cam and nitrous. I would think the 42's would be fine but I am waiting to see what LG suggest.
Old Sep 14, 2007 | 09:25 AM
Billdog350's Avatar
Billdog350
Lots of reputable tuners have run injectors at 130% duty cycle with a solid AFR and no injector issues.
Duty cycle is just the computers estimate....based on other parameters. Just because the computer "thinks" your injectors are maxxed out, doesn't mean they are. If your AFR is solid, you're good to go.
Old Sep 14, 2007 | 09:29 AM
kromberg's Avatar
kromberg
My old 383 setup made 420 rhwp with 26lb injectors. They where close to the max duty cycle, but no problems.
Keith
Old Sep 14, 2007 | 05:14 PM
FKING1's Avatar
FKING1
Originally Posted by 99 vett babycar
you're fine
I have a similar setup on my 00 with ported heads & larger valves. My tunner said the stock ones were good.
To Do I Need Larger Injector Size?
