sending a PCM
Old Sep 12, 2007 | 02:22 PM
bgreen83's Avatar
bgreen83
Default sending a PCM
hey, I need to send my pcm to vette doctors to get it looked at.
How would I send it? is it just like sending a file or would I actually have to take something off the car and wont be able to drive it?I just recentyl got the vette so I'm very noobish when it comes to all this.
Thanks in advance for any help!!
Old Sep 12, 2007 | 02:42 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
The PCM (Powertrain Control Module) is a computer, you need to take it out of the car and ship it. You cant drive it when then PCM is not in the car.
Old Sep 12, 2007 | 03:11 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Disconnect the battery.
jack up Car and remove passenger front wheel
Remove rear and under frame splash guards.
Using a 7mm socket undo terminal pins and bracket holder.
Wrap it in a lot of bubble wrap and plastic.
Old Sep 12, 2007 | 10:19 PM
bgreen83's Avatar
bgreen83
thanks, it will suck i wont be able to drive my baby. I'm going to look for some state wide dyno tuners that can maybe help. if not then ill just have to be without my baby for a few days or weeks!!
Thanks again all.
Old Sep 13, 2007 | 07:38 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Thanks again all.
I'm sure if you post up where you live someone will know of a local tuner.
Also, I read your profile, you have coupe not a FRC based on your avatar.
A FRC looks like this.
Old Sep 13, 2007 | 07:42 AM
Bugaboo's Avatar
Bugaboo
Just call Carmen, great guys.
To sending a PCM
