Terrible Engine Rattle
Old Sep 12, 2007 | 05:22 PM
axikowboy's Avatar
axikowboy
Default Terrible Engine Rattle
I have a loud mettalic rattling sound coming from the engine bay. It is hard to locate the exact source of the sound, but appears to be in the front around the pullies. The exhaust note sounds normal and there are no other abnormal sounds/movements. Any ideas on what this could be? I read some past post and from what I can gather, it sounds too loud to be engine knock (I use 93 octane), could it be tensior (sp?) pulley or the idler pully, please help. The sound it not a sqeak.
It sort of sounds like a centrifigal supercharger from the videos I have heard. The whole "marbles in a jar".
Car Stats
97 A4
Engine: Stock Shortblock, TSP LS6 Heads, G5X3 @ 112, FAST 90, LS2 TB, LG Pro LT, B&B PRT Catback, Halltech Stinger, Vig 3200 Stall, Z06 3.42s,
Old Sep 12, 2007 | 06:32 PM
jirasvet's Avatar
jirasvet
Take your belts off and see if it goes away.
Eliminating all accessories is the first step.
Could be a bad bearing in your alternator or waterpump.
Actually sounds like what you are describing is a bad A/C clutch.
Can not hear it so I am guessing
Old Sep 12, 2007 | 07:58 PM
elwoodb's Avatar
elwoodb
Cruising
I just had a similar problem. Sounded like a bad idler pulley, replaced it and the arm as well- nothing. Took it to my dealer and it turned out to be the tranny lines rattling against the bottom of the car! Just pulled them away and problem solved...
Old Sep 12, 2007 | 08:15 PM
axikowboy's Avatar
axikowboy
Thanks for the help / ideas. The sound was kinda stong by the alternator, so that might be it. I'll see what happens when the belts are off.
Old Sep 13, 2007 | 01:48 AM
Point & Shoot's Avatar
Point & Shoot
Car Stats
97 A4
I had a similar noise like a deep metallic grinding sound especially at idle - it sounded really bad. Turned out to be the alternator AND water pump.
While I was in there, I swapped out the belt tensioners & put on Goodear Gatorback belts and ............ SILENCE, PURE SILENCE.
In fact, a co-worker commented how quiet the car ran !!
Old Sep 13, 2007 | 06:09 PM
axikowboy's Avatar
axikowboy
Thanks again guys!
Got some more info, it is def RPM related b/c when I rev the motor the frequency picks up, but then goes away? Maybe aroudn 2 - 2.5K. Is this thing safe to drive anywhere, or is it a do not touch until fixed?
Also how exactly do you loosen your belts? How long can you run the motor with the belts off and not damage anything? When putting it back on, do you need to torque it to a certain spec?
Can you tell I'm new to a lot of this stuff?
Old Sep 13, 2007 | 06:42 PM
jirasvet's Avatar
jirasvet
Also how exactly do you loosen your belts? ?
On/Off procedures are the same.The main belt is the easiest to get off. All you need is a ratchet and i believe a 15mm socket. Relieve the tensioner by placing your socket on the pulley bolt and rotating the tensioner clockwise. Same for A/C not sure of socket size. Only problem for A/C is that you got to crawl under car. Make sure when re-installing that your belts are properly aligned and in the proper pulley groves. Would not want a belt to get chewed up or pop off.
Long enough to determine if it is your accessories. Make sure some one watches the temp gauge. Would not want to over heat.
Old Sep 13, 2007 | 09:49 PM
Neil Baker's Avatar
Neil Baker
Do you know what exactly your dealer did, where were the lines hitting?
Old Dec 6, 2007 | 07:13 PM
RedC5's Avatar
RedC5
I think I have a bad AC clutch....bad rattle at idle, but when I turn on the AC or defrost, the loud sound goes away. Anyone else ever have this?
Old Dec 7, 2007 | 11:30 AM
jedblanks's Avatar
jedblanks
Is your crank pulley wobbling? Maybe its bad enough to hit. if you still hear the sound after your remove the belts, you may have the infamous seperating harmonic balancer
edit -- after reading the above post, the only way mine could be true is if the AC puts enough strain to slightly stop the wobble.
Most likely AC clutch/bearing.
To Terrible Engine Rattle
