Alignment problem on Z-06 catback
Old Sep 13, 2007 | 10:53 PM
SUNNYD 95's Avatar
SUNNYD 95
Default Alignment problem on Z-06 catback
I need some help AGAIN. I just instslled a Z-06 catback on my 98 coupe, and the left muffler hangs down alot lower then the right, any idea how I can get it up higher to match the other side. I won't use heat so what can I do. Thanks guys and ladies for your help again.
Jim
Old Sep 13, 2007 | 11:33 PM
88sk's Avatar
88sk
did this a few times with mine ,you gotta loosen the other pipes on both & adjust both to compensate,when I swap between Borlas ,TI's & stock theyre all different to line up,I got a lift so it makes it easy
Old Sep 14, 2007 | 09:05 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
if'n i recall correctly, there are two slots on the rubber insulator the mufflers hang from. Maybe ya got one in the wrong slot (stock was the lower slot, i believe)
Old Sep 15, 2007 | 09:20 PM
SUNNYD 95's Avatar
SUNNYD 95
A quick update on my exhaust, I loosened up the pipes and wiggled em around, tightened everything checked it and did it all over again and once more after that. On the third try I checked them and it looked real good. Thanks for everyones help it worked out and looks GOOD.
Jim
To Alignment problem on Z-06 catback
