Replacing front spring adjusting studs??
Old Sep 14, 2007 | 10:48 PM
bliehr's Avatar
bliehr
Default Replacing front spring adjusting studs??
Bought a used 97 c5.
Someone, during it's life cut the rubber pads off the adjusting bolts to lower it. I dont like it . Too low and no cushion.
Can they be replaced without removing the A arms etc.
Bob
Old Sep 15, 2007 | 01:29 AM
striper's Avatar
striper
You will have to disconnect the lower control arms at the ball joint to remove/replace the adjusting bolt, however that will not be your biggest problem. Finding stock replacements will be the real problem. The cutoff bushing does not affect ride quality very much so I wouldn't bother replacing it. Instead, just adjust the bolt up to the height you prefer.
