help id these connectors?
Old Sep 15, 2007 | 11:53 AM
busta's Avatar
busta
Default help id these connectors?
I was hoping someone could help me identify a few connectors for a C5 Chassis project that I'm building. The harness and chassis are from 2002. Thanks Tim
pic 1 - 16 wires from the same bundle as the pcm connectors (connector missing)? Both Blue and red wires are accounted for. Edit-Got it, this goes to the TAC module, I had to buy a new connector from GM
pic 2 - two connectors A-B (passenger side fuel tank)? Edit I found 'A' it goes to the harness on top of the tranny. 'B' has the same pins as the tank but both connectors are female. Unless something goes between them?
pic 3 - four connectors A-B-C-D (passenger side front of car and one green plug in the background)? Edit-these go to the dash harness...
pic 4 - 3 connectors A-B-C (Near PCM) ? Edit-these go to the dash harness...
Pic 5 - 5 connectors A-B-C-D-E (Near PCM) ?
Old Sep 15, 2007 | 01:04 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Originally Posted by busta
I was hoping someone could help me identify a few connectors for a C5 Chassis project that I'm building. Thanks Tim
In this pic you are missing the red connector that goes to your PCM. For information on wiring this connector, you can send eurospec1 a PM. He changed his 97-98 PCM over to a 99-00 and will have some good info to share.
For the rest of the pics, Bill Curlee is probably the man to contact. I'll PM both of them and make them aware of your thread. Both of them are extremely helpful guys. Good luck.
You wouldn't happen to be building a GTM would you?
Old Sep 15, 2007 | 03:38 PM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
Hello,
Hmm this is quite the interesting question!
First i have to ask what year is that harness?
Second that blue PCM connector is broken, your gonna need to replace that.
For those 16 wires in your hand near the PCM connectors your probably gonna have to get a pcm pinout of the exact year of your harness, and go through the PCM connectors 1 wire at a time and figure out which ones are missing, from there you can probably go by wire color and figure out where those go, those are pins that go into your PCM.
let me know what year that harness is and ill try to help ya out.
Old Sep 17, 2007 | 12:37 PM
busta's Avatar
busta
Default 2002
the chassis is a 2002 automatic, thnks
Old Sep 20, 2007 | 10:17 PM
busta's Avatar
busta
Default plug wires
I found this picture and I think this picture may be the one that is removed from the wires in the first picture. Does anyone know what module that is under the pcm in this pic.http://i182.photobucket.com/albums/x...1/DSC00922.jpg
Old Sep 20, 2007 | 10:31 PM
LoneStarFRC's Avatar
LoneStarFRC
It should be the TAC module (Throttle Actuator Control) used all C5s.
To help id these connectors?
