'98 Tuner
Old Sep 16, 2007 | 11:03 AM
MagRedConv's Avatar
MagRedConv
Default '98 Tuner
Hello,
I'm new to the forum (member) but have read all info you all have offered; well done. My question is in regards to handheld (Predator, Hypertech) tuners. It seems that the Hypertech is the only option for owners of '97-98 cars (don't get it) and as such I'm hoping to gain some insight as to it's value (usefulness; shift points, etc.) from fellow owners of '97-98 cars. Thanks
Old Sep 16, 2007 | 12:29 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
It's easy to use and easily reversible. I found it most useful for messing with transmission shift firmness, rev limiter, and fan cooling temps. I'd buy used before I'd buy new. If you have more advanced tuning needs, there are more suitable options, but for a near stock car it's okay.
There are comparatively few options for the early years because the market is smaller (fewer cars produced).
You might also check out the Scan & Tune forum.
Old Sep 16, 2007 | 01:07 PM
MagRedConv's Avatar
MagRedConv
Thanks so much for the reply: I was beginning to think that because I was a new respondent I had to prove myself.
Old Sep 16, 2007 | 01:09 PM
MagRedConv's Avatar
MagRedConv
BTW... I'm Texas too; Austin
Old Sep 16, 2007 | 02:02 PM
Rag-Top Rick's Avatar
Rag-Top Rick
Originally Posted by MagRedConv
Hello,
You are correct about the limited selection of programmers for the early C5`s, however, for slightly more money the Vinci-Crane programmer is superior to the Hypertech as it has many additional features.
Example: Adj timing, adj air-fuel ratio, and tunes for many of the popular head/cam combos in addition to fan temp settings, shift points and firmness, etc.
Read about it here under C5 section: www.vincihiperformance.com
Old Sep 16, 2007 | 02:17 PM
MagRedConv's Avatar
MagRedConv
UR The best
Old Sep 16, 2007 | 03:31 PM
Redvette_22's Avatar
Redvette_22
I had one when they first came out and returned it. It locked the PCM once on download, jammed with the second unit and had to be redone, and when it did finally download (3 units sent by Hypertech) it did not do anything for the performance, just lowered the fan temp settings.
Old Sep 18, 2007 | 09:20 AM
ToplessTexan
I have a sister there.
To '98 Tuner
