Oil Gauge Maxed out! Help!
Old Sep 17, 2007 | 02:31 PM
ZeroHer0's Avatar
ZeroHer0
Default Oil Gauge Maxed out! Help!
On my way home for lunch, my oil gauge maxes out at 80 and my DIC reads 130! I have enough oil and oil only has like 500 miles on it. I dont hear any differnt engine ticks or noises. Anyone had this problem or know of a reset? My gauge reads 80 with ignition on, but not cranked. This is so wierd. My first guess is a oil pressure sensor.
Old Sep 17, 2007 | 02:34 PM
randy814u's Avatar
randy814u
yup and if you want to fix it yourself, this will help.
http://forums.corvetteforum.com/showthread.php?t=958008
Old Sep 17, 2007 | 02:53 PM
rws.1's Avatar
rws.1
or if you want to re-locate it check out the sticky at the top of this section...
Old Sep 17, 2007 | 02:55 PM
Oldvetter's Avatar
Oldvetter
A sure sign is if your oil pressure reads high with the ignition on, but the engine not running.
Old Sep 17, 2007 | 03:39 PM
ZeroHer0's Avatar
ZeroHer0
Thanks for the quick replies. I figured it was the sensor but had to be sure. Running into a few problems/ replacements on this car atm and didn't want to have to budget an engine rebuild. Once again you guys come through.
Old Sep 18, 2007 | 10:47 AM
ZeroHer0's Avatar
ZeroHer0
Anyone ever replace without removing intake manifold? Will i have to find someone with carnie hands to do this or is the intake overlapping the sensor?
Old Sep 18, 2007 | 11:22 AM
thetaxman's Avatar
thetaxman
if you cut the cowl, you can do it without removing the intake.
Old Sep 28, 2007 | 03:23 PM
rpressley's Avatar
rpressley
7th Gear
Default I've just developed the same problem with oil pressure gauge
Last weekend the same thing happened to me Oil Pressure Guage goes to 80 and DIC read 130 with or without the motor running. Did you try to fix it yet? Was it the sensor. Looks like a real bear to replace....
Randy
Old Sep 28, 2007 | 03:26 PM
rpressley's Avatar
rpressley
7th Gear
Any pcitures on how to cut the cowl to replace oil pressure sensor without removing the intake?
randy
Old Sep 28, 2007 | 03:46 PM
spider94r's Avatar
spider94r
randy
If you read the sticky thread at the top of the tech forum about the sensor relocate procedure, I think there are also some pictures of the cowl-cutting method for replacing the sensor, or at least links to them.
Old Sep 28, 2007 | 04:29 PM
Slick Rick's Avatar
Slick Rick
This just my opinion why cut a hole, you just decreased the value of your vette anywhere from a 1000 to 2500 bucks, It takes all of an hour to replace it the correct way,and if you get tired of replacing it you can always relocate it.............
Old Sep 28, 2007 | 08:39 PM
spider94r's Avatar
spider94r
Originally Posted by Slick Rick
This just my opinion why cut a hole, you just decreased the value of your vette anywhere from a 1000 to 2500 bucks, .....
Respectfully, I don't see that happening. You can't see the hole after everything is put back together. It's not like you're cutting a hole in the fender. Since the replacement sensors have a habit of dying within a few days, moving the intake manifold more than once is not worth the trouble.
Old Sep 29, 2007 | 10:51 AM
Nyvetteguy007's Avatar
Nyvetteguy007
I cut the cowel....made sure I cut it nicely so I could put it back...replaced the sensor...put the cut area back..sealed it with black silicone...and it looks as if nothing was done...now I have an easy access to this part that is prone to failure.
Risking intake manifold leaks to me isnt worth the trouble....so far so good, its been a few months now...no issues...
Old Oct 1, 2007 | 06:14 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
Well, I think I have developed the same problem today. Engine off, gauge at 80 PSI and DIC reading at 120 PSI. I looked at the "How To" instructions and quite frankly I'm a little leary of tackling this job myself. How bad do you think the Stealership will gouge me for replacing the sensor?
Also, does it hurt anything to be driving with a bad sending unit??
Old Oct 1, 2007 | 08:04 PM
Slick Rick's Avatar
Slick Rick
About 300 to do at the dealers. 2 hrs labor plus parts. If its not leaking real bad out of the sensor not going to hurt anything to drive it. I drove mine a couple hundred miles before I changed mine. Its not to bad a job to do yourself. It took me about an hour to do it myself. First time. Foolow instructions that you found on forum very simple. You do not have to replace intake gaskets or remove fuel lines. You just have to move manifold up enough to get to sensor..........
Old Oct 2, 2007 | 08:05 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
Yeah, like anyone will see it
To Oil Gauge Maxed out! Help!
