Traction/Active sytems?????
Old Nov 10, 2001 | 11:01 PM
ZO6LS6's Avatar
ZO6LS6
Default Traction/Active sytems?????
Do they reset, after you turn the engine off????
I had set my ZEE in the "Comp", mode, and figured it would STAY there, till I changed it........
Well, while running a 1/4, the darn AH/TC message flashed, and I felt a loss of power, momentary........but enough to screw up my run....
Fact or fiction........I did not manually reset it to TC/AH ON.........from COMP mode......
I must "Assume", that it reverts back to the "safe" mode when shut off overnight........... :confused:
Old Nov 11, 2001 | 09:03 AM
c5wrench_2001's Avatar
c5wrench_2001
Default Re: Traction/Active sytems????? (ZO6LS6)
Every time you turn your ignition on, your TC/AH is always on.
You must turn it off. c5wrench
Old Nov 11, 2001 | 05:08 PM
ZO6LS6's Avatar
ZO6LS6
Default Re: Traction/Active sytems????? (c5wrench_2001)
C5Wrench, thanks............ :yesnod:
To Traction/Active sytems?????
