During a brake service today, I mistakenly told the tech to use Dot 4 Brake Fluid, and being a good tech, he ignored the label printed right on the fluid resevoir and did just that.
What are the risks of using Dot 4 over Dot 3. Am I in danger of doing any damage to my brake system?
Dot 4 has higher boiling points both dry and wet (brake fluid absorbs water over time). So basically it is a Premium type of fluid, with the associated higher price.
The only problem you would have would be if he used Dot 5 which is a different type of fluid.
Speed-Racer,
DOT 5 is silicone based fluid. Do not use it!
DOT 5.1 is synthetic and is ok to use. (I think)
I have used nothing but DOT 4 in my vettes for many years.
Yes it is compatible with DOT 3.
You have a better fluid in now than you did.
Rich-
That's a great link, thanks. One minor corection, the Ford HD fluid now comes in plastic bottles and thus should not be stored for long periods before use.
Rich-
I'm using the Super Blue now. It comes from Germany in a very robust metal can. For my type of drivng it seemed to offer the best all around solution.
I got mine at http://www.thelapd.com
