TPS (Old Style) Question
Old Sep 19, 2007 | 12:55 PM
mtwalet's Avatar
mtwalet
Default TPS (Old Style) Question
I tried the archives but couldn't find the answer to this test question...
Is there any way the OLD STYLE tire sensors can be checked for remaining battery life when the sensor is exposed for tire changing??
Old Sep 19, 2007 | 12:57 PM
jovette's Avatar
jovette
Not that I know of.
Old Sep 19, 2007 | 02:09 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by jovette
Not that I know of.
If in doubt, change'em out.
Old Sep 19, 2007 | 07:33 PM
Greg_E's Avatar
Greg_E
A date code is molded into the plastic case. All you can do is check that. The battery is sealed inside the sensor. Look for what looks like a small clock face, that is molded in the case. The arrow points to the month. On either side of the arrow will be a number indicating the year of manufacture. EX. arrow points to 10, and 9 8 are in the center on either side of the arrow= Oct, 1998 mfg date.
If it's at the 7+ year mark, it's probably not going to last much longer unless you have a car with low milage, where the battery has been unused for most of it's life. If your the DIY type, there is a thread with pictures, that shows what's involved in replacing the battery. It's in the archives.
To TPS (Old Style) Question
