Fog lite
Old Sep 19, 2007 | 04:35 PM
eberlemike's Avatar
eberlemike
5th Gear
Default Fog lite
Nee to replace a fog lite on a 2000 vete, what is the best way to get at the lite and once you get your hand on the lite fixture, how do you get the bulb out and the new one in. Sounds dumb but had no luck so far. thnks
Old Sep 19, 2007 | 05:19 PM
bighank's Avatar
bighank
Default fog lights
Put 885 bulbs in there BOTH SIDES you will think they are HEADLIGHTS.
885 is 50 or 55 watts and the 889 or 893 in there now is only 37 watts.
As I remember you need to take out a few black screws holding the mud splash cover or whateveryoucallit underneath the front. Reach in and I think they untwist. OR...
Turn on the headlights or crank them out manually, remove the 3 screws holding on the plastic black shrooud, and reach in a long way. If your hands are as big as mine you might attack from the bottom. When done use a torx driver to reaim the lights. Mine were too low. Park about 20 feet from a garage door or wall and adjust similar to where your headlights are.
Have Fun BIGHANK
Old Sep 19, 2007 | 06:00 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
With the 885s.
Also, do not forget to aim them, they come all screwed up from the factory.
http://www.c5forum.com/diy/fog_lamps.php
Old Sep 19, 2007 | 06:01 PM
jdmvette's Avatar
jdmvette
Night Owl for life
ditch the halogen replacements and go with HIDs.
Old Sep 19, 2007 | 11:42 PM
MACKASH's Avatar
MACKASH
Old Sep 20, 2007 | 06:19 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
Have Fun BIGHANK
Excellent advice here. I have replaced mine once before the second way and it works perfect. I shouldn't have read anything about foglamps because one of mine is now out. Oh well, whatever I do I don't want to read about vasectomies.
Old Sep 20, 2007 | 01:03 PM
71sx's Avatar
71sx
The easiest way to change the fog lamp bulb is to:
1. raise the hood
2. raise the headlights
3. remove the headlight side-cover on the engine side of the assembly
4. reach down in the space you've created, unplug the fog lamp pig-tail, twist the bulb, remove, and replace.
No getting on the floor, 4 screws to back out.
Old Sep 20, 2007 | 08:45 PM
BanditDude's Avatar
BanditDude
1. raise the hood
To Fog lite
