C-5 tech
Old Nov 11, 2001 | 10:49 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default C-5 tech
OK who knows how to remove the electrical connector from the 2002 MAF. they are different than the older ones,does it need a special tool to unlock it? :confused:
Old Nov 11, 2001 | 05:38 PM
c5wrench_2001's Avatar
c5wrench_2001
Default Re: C-5 tech (clem zahrobsky)
Pull the gray tab away from the sensor, it will move about an 1.8inch, and then you can push down the black part to remove the connector.c5wrench
Old Nov 11, 2001 | 06:40 PM
clem zahrobsky
Cruise-In I Veteran
Default Re: C-5 tech (c5wrench_2001)
thank you sir i will give it a try.
To C-5 tech
