Ok code junkies I need info plz
Old Sep 19, 2007 | 06:41 PM
One Nut's Avatar
One Nut
Default Ok code junkies I need info plz
My car failed smog has a code 1153 O2 sensor or Ho2o.
Question is it also coded again with 1416 a few days later can that o2 sensor also create the 1416 code?
The car smells like it is running rich and does seem to idle a bit rough at times. Its going to RPM MOTORS Charlie on Friday I do have the #1 O2 sensor should I also get the HO2o sensor also just in case?
Thanks For the help
onenut
Old Sep 19, 2007 | 06:53 PM
One Nut's Avatar
One Nut
come on give it up
Old Sep 20, 2007 | 01:15 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Originally Posted by One Nut
come on give it up
P1153 is basically a lazy O2 sensor.
P1416 Air System - Code bank 2
Doubt they are related. I'd change the O2 sensor and see if that clears the other code. You sometimes get a false code because of other problems.
Old Sep 20, 2007 | 01:52 AM
DT's Avatar
DT
Yeah, the 1153 is slow/low response on a rear 02 from your header/highflow cat setup. Pretty common and can be easily edited out (I did it myself with HPTuners). It doesn't effect the tuning, it's just an emissions alert.
The 1416 is a stuck/bad Air Check Valve - basically it's a valve that prevents reverse airflow in the air system that's used to create cleaner starts (yet another emissions control). There's two valves (one per side) and 1416 is in a tough place to get to. Some people have had luck spraying some cleaner into the intake side:
http://forums.corvetteforum.com/show...ighlight=p1416
Excellent step-by-step.
I'm eventually going to remove all this jive in my car - plug changes will be easier, etc., though I see from your location, you'll need to stick with all the OEM emissions equipment.
Good Luck!
DT
Old Sep 20, 2007 | 09:11 PM
One Nut's Avatar
One Nut
Good Luck!
DT
Great tip I followed it and did as mentioned and BADABING it cleared the code I'm replacing the rear o2 sensor tonight hopefully it clears up the other code. It also coded the cat 430 If the stars allighn the o2 replacement will clear that one also. The car has a little over 1000 miles on the entire exahust system. Dynatech LT with their bullet cats X pipe and borla stingers. Thanks again for the help... Then off to charlie tomorrow
To Ok code junkies I need info plz
