Help me please!!
Old Sep 20, 2007 | 01:14 AM
Frmdabay's Avatar
Frmdabay
Default Help me please!!
Hi guys and gals!
I have a huge problem!! I decided to change my OEM thermostat to a 160 degree one. Installing it was simple. I flushed my whole system and added 6 quarts of prestone antifreeze dex-cool then I topped it off with water. When I went to start the car I noticed that the check engine came on. I didnt think much of it because I figured I would just get to read the code tomorrow. So I tried to go out to the store and I noticed that my temperature started to increase as my speed increased. My gauge read 250 deg F at one point then it would drop to about 213 then back up. Anybody have an idea of what it might be before I take it to a shop.
Old Sep 20, 2007 | 01:35 AM
SLPRC5's Avatar
SLPRC5
Originally Posted by Frmdabay
Hi guys and gals!
You have AIR in the system....remove the cap, let it run for a few minutes...until it reaches a certain temp...you may need to add some coolant after wards. Better yet do a search on air in cooling system.
Good luck
Old Sep 20, 2007 | 01:45 AM
Frmdabay's Avatar
Frmdabay
Ok thank you very much ill try that right now!
Old Sep 20, 2007 | 01:58 AM
SLPRC5's Avatar
SLPRC5
Here is all the info you need on changing the T-stat.
http://forums.corvetteforum.com/show...lant+procedure
Old Sep 20, 2007 | 02:27 AM
Lone_sword's Avatar
Lone_sword
You have to let the car run while the radiator cap is off. Keep topping off the coolant till it stops draining then your set.
To Help me please!!
