flywheel???
Old Sep 20, 2007 | 04:04 AM
wettvette's Avatar
wettvette
Default flywheel???
2002 vert done 36000 miles, bought a clutch kit,LuX brand, and it came with a flywheel. do they normally come with flywheels and why ? does anyone know that brand? is it anygood?
Old Sep 20, 2007 | 10:29 AM
ArKay99's Avatar
ArKay99
Are you talking about a Luk clutch and flywheel? If so, you can get them with an aluminum flywheel. Much lighter than stock = more hp/tq to the rear wheels. when you change the clutch and pressure plate you should change the flywheel too. While you are in there, you may want to change the slave to a Z06 slave. Supposed to be a little more tolerant of the 'sticky clutch pedal syndrome'. Do a search on clutch replacement. There is a lot of info regarding it and related issues.
Old Sep 21, 2007 | 03:42 PM
wettvette's Avatar
wettvette
To flywheel???
