TPS read lower than actual?
Old Sep 20, 2007 | 11:19 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Default TPS read lower than actual?
On my '99, the sensors all read about 5-6 lbs lower than my hand gage. One of them keeps showing up on the DIC--(reads 23lbs), when in fact they are all set to 30lbs, but the read-out says they are between 24- 27 lbs.
Is this normal? Are these suppose to be accurate?
Old Sep 20, 2007 | 11:21 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
They are accurate as with my handheld. Have you tried another handheld, to see if there is a difference?
Old Sep 20, 2007 | 11:30 AM
BlackZ06's Avatar
BlackZ06
I'd be suspicious that the handheld is wrong. I could understand one TPS being off, but ALL being off exactly the same amount ... highly unlikely. Try another gauge.
Old Sep 20, 2007 | 11:42 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
done......i will pick up another gage tonite and see....but, this one I bought last year was not a cheapee, so I believed it.
On the other hand, I'd rather replace it intsead of sensors.
To TPS read lower than actual?
