Service Column lock
Old Sep 20, 2007 | 02:26 PM
03z06BLK's Avatar
03z06BLK
Default Service Column lock
My mom 01 is saying service coulmn lock so she cant drive is there a way to bypass that so we can take it to chevy thank you
Old Sep 20, 2007 | 02:53 PM
87SAM's Avatar
87SAM
With the key in the off position, try pulling on the steering wheel to the left hard with both hands. While still applying pressure on the wheel, turn the key to the on position.
After this you will need to read the stickies at the top of the page and a run a search. This can be a long drawn out affair.
Old Sep 20, 2007 | 02:58 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
If you can't get the column to unlock you are screwed and will have to have car towed to chevy dealer. Bypass does not work once sterring column has locked.
If you get it unlocked take it immediately to chevy dealer and have fixed per most recent recall, which is number 3.
stickies have more info.
Old Sep 20, 2007 | 06:01 PM
LoneStarFRC's Avatar
LoneStarFRC
AC54ME has vast experience on this issue.
You out there today Dennis?
Old Sep 23, 2007 | 02:40 PM
03z06BLK's Avatar
03z06BLK
Thank guys yea i got to unlock by turing the car on jerking the wheel left to right that turn in to the start and got it that way how can i prevent this happen to her 01 again thank you
Old Sep 23, 2007 | 02:44 PM
fsuforever's Avatar
fsuforever
works for me as well
Old Sep 23, 2007 | 03:07 PM
John02Hawk's Avatar
John02Hawk
Old Sep 23, 2007 | 03:22 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Also check battery level and charge. Biggest reason for column lock problems are due to low voltage from tech articles that I have read.
Try disconnecting battery and charging it up for a while and then reconnecting.
Old Sep 23, 2007 | 04:16 PM
LoneStarFRC
Originally Posted by John02Hawk
To Service Column lock
