Threading c6 shifter
Old Sep 23, 2007 | 12:05 AM
jjvet's Avatar
jjvet
Default Threading c6 shifter
Does any one know where to buy just a 9/16 18 die or a shop that might perform this service and not try to rip me off.
Need to put about 1,1/2-2 inches of thread on a c6 shifter shaft
I am NE of Atlanta. Thanks
Old Sep 23, 2007 | 12:13 AM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
try to find a machinery supplier in your area, they will have the die size you need. if one is not close to you and you have a few days, do a search on mcmaster-carr.com ( or carr-mcmaster.com ). they have everything from a-z for the machining industry. i don't think sears has anything over 1/2.
Old Sep 23, 2007 | 08:40 AM
fastdriver1's Avatar
fastdriver1
I'm going to suggest taking the shifter out and taking it to a GOOD machine shop. I threaded mine and the problem comes in because of the flat spot on the shaft. A coventional die has three cutting surfaces and will not work with the flat spot. I think my shop's die had four surfaces. They charged me $5 or $10 to do it and I thought that was fair.
Hope this helps.
To Threading c6 shifter
