Very High Oil Temps With Cooler !!!!
I have major oil temp issues when I track my car. Temps quickly go over 300* ........ they are around 210-220 normal driving.
I have tried using the Engine Oil Cooler (EOC) in my Dewitts. I have tried using an external cooler (11x8 B&M) with the same results. The external cooler is located behind the driver front wheel well (wheel well liner is cut to access fresh air)
Here are the possible changes I am considering and would like input on these or any other suggestions would be great. Keep in mind that I alread have a very large cooler for my tranny sitting in front of my radiator condensor.....this is obviously the best place but my car is an A4 and must have this cooler here.
1. Move the cooler (or one that fits) to the front bumper area. Where the Z06 fog shrouds are open. Or open the front license plate area.
2. Stack another cooler in front of the radiator possibly affecting air flow to my Calloway Honker or the tranny cooler and radiator.
3. Run another cooler in series
4. Run same or other cooler from bumper area in series with the EOC in the Dewitts radiator.
If running two coolers causes an oil pressure issue is there a remmedy such as larger oil pump.
Thanks,
DH
Any thoughts on oil pressure loss from two coolers ???
DH
Arnel
Are you saying that you see little difference in oil pressure or in oil temps.
What are your oil temps and where are your coolers, and what size are they ?????
DH
Arnel
I know they're working cause what I fight is water temps which I barely manage to keep above 240.
Arnel
Would your cooler setup work in the stock front end or in the Tiger Shark necessary.
Which kind/size are your coolers???
Any Pics ????
DH
Temp reduction should be as good or better than the brake duct location, canyon carving on the hottest days (97*+) I saw aprox 20*+ reduction in tranny temps with stad-alone cooler in the brake-duct cavity, even more on cooler days!
Arnel
Although I'm not sure exactly what if any cooling actually gets to the front brakes thru those ducts I would not block them as I intend to keep tracking the car. I would think there is more room in the fog shroud area. How big a cooler did you get in the brake duct spot. Did Andy put it in ?????????
Glad you got good results on the canyon runs
DH
Arnel
That is a fabulous job. I hope you don't mind .... I am going to post your pic in the thread I started in RoadRacing Forum.
Maybe the TigerShark changes things. But in the stock setup the air passing thru the fog shroud goes up and over the radiator shroud into the engine bay. It doesn't go thru the radiator.
I am hesitant to cut holes in my hood. This will be a last resort. I do remove some of the rear hood seal rubber as some think air will escape thru the back hood and over the windshield. But others say this is a high pressure area and the reverse happens.
DH
DH
Arnel
Arnel
I've never seen a Tiger Shark setup ... only pics or from a distance.
Is it that you no longer have a radiator shroud and all air enters the front, none from the bottom????
DH
