Manual Fan Switch
Old Sep 27, 2007 | 12:47 AM
99BlkVette's Avatar
99BlkVette
Default Manual Fan Switch
Hey Guys. Has anyone done or have information on wiring up a manual fa n switch? My buddy did this to his Trans-Am and he tied into the computer rather than running directly to the relays. I tried searching but haven't found out what wires to connect. If you have any info or links to share, please post. Thanks.
Old Sep 27, 2007 | 09:44 AM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
Do a search on Ranger on here he has a write up on wiring a C5 manual switch for the drags. You can make a switch type system to work with it as well.
Old Sep 27, 2007 | 11:43 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The PCM outputs two different ground or low signals to the relays in the engine compartment fuse box, to turn on the fans as required. If you can identify the wires for your car, you can easily wire it in. You'll need a formal schematic.
Old Sep 27, 2007 | 12:44 PM
Ranger's Avatar
Ranger
Thanks, dwjz06.
Here is a direct link to my C5 Fan Trick
Ranger
Old Sep 27, 2007 | 06:34 PM
99BlkVette's Avatar
99BlkVette
Good write up on the fan trick, Ranger.
Thanks for the help guys. Does anyone have a formal schematic of the PCM?
Old Sep 27, 2007 | 08:48 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I have the diagrams, But it lists it by fuse #s. What are they? That trick above, you could easily run that through a switch to the inside of the car. Just switch the length of wire.
To Manual Fan Switch
