Speaker problem - passenger door
Old Nov 12, 2001 | 02:30 PM
SEAMOORE's Avatar
SEAMOORE
Default Speaker problem - passenger door
My 99 FRC has just developed a speaker problem in the right front speaker. It's a distorted rattelee type sound, kinda like when you use to get a crack in the old speakers. It's not in any of the other speakers but when i use fade and balance and isolate to another speaker i can still hear the noise in the right front speaker - any ideas? thanks in advance. P.S. I don't think it's the rattling emblem problem.
Old Nov 12, 2001 | 02:33 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Speaker problem - passenger door (SEAMOORE)
Is it possible the speaker could be blown?
Old Nov 12, 2001 | 03:12 PM
steve badalamenti's Avatar
steve badalamenti
Ah Ha! To give credit where due, one of the forum members (can't remember who) has discovered that
the rear vertical edge of the door panel rubs the painted part of the door on the passenger's side . It
vibrates and sounds just like a blown speaker when you crank the volume up.
A few tiny pieces of thin weatherstripping stuffed betwen the panel edge and painted part cures the
pproblem. I had the same problem, and this cure works perfectly.
[Modified by steve badalamenti, 1:14 PM 11/12/2001]
Old Nov 12, 2001 | 03:21 PM
allanlaw's Avatar
allanlaw
It could also be the famous Bose logo rattle. Stick a little piece of cardboard under the logo (between the logo and the speaker grill) and see what happens.
Old Nov 12, 2001 | 06:09 PM
jayleone's Avatar
jayleone
It could just be a bad speaker connection. If the speaker can't draw enough power as volume increase or during increased bass, it can cause that noise. I had a loose connection at the speaker, once it was fully connected, everything worked fine.
Old Nov 12, 2001 | 08:44 PM
PHAT CHANCE's Avatar
PHAT CHANCE
Default Re: Speaker problem - passenger door (allanlaw)
I'll bet serious money it's the bose logo rattling.
I pulled mine off and stuck them back on with black silicone. I've never had a problem since.
-Chance
Old Nov 13, 2001 | 08:40 AM
SEAMOORE's Avatar
SEAMOORE
Thanks everyone - all your help is certainly appreciated. First spare moment and i'll check it out. Again - thanks
Old Nov 13, 2001 | 03:48 PM
Tek's Avatar
Tek
I am curious what you found. I have a similar problem with my passenger side speaker as well as my driver side rattling my window if it is not fully up or down.
Tek
Old Nov 13, 2001 | 05:09 PM
PHAT CHANCE
Default Re: Speaker problem - passenger door (Tek)
Had the same window problem. I took the door apart and found a REALLY loose bolt, tightened it and the problem was solved.
Kinda lame you have to get in there and take the door apart, but having the rattling stop was DEFINITELY worth it.
Old Nov 14, 2001 | 11:59 AM
lostsoulny's Avatar
lostsoulny
Default Re: Speaker problem - passenger door (PHAT CHANCE)
I have a similar issue I am going to look into it this weekend I am hoping it is just a vibration rattle as it seems to happen with long bass notes, and not al the time so I dont think it is a blown speaker.
To Speaker problem - passenger door
