Drivers half shaft
Old Sep 27, 2007 | 06:48 PM
ICUALL's Avatar
ICUALL
Default Drivers half shaft
Okay got the new exoskel clutch in and trans rebuit by T-56 in Houston (great people to deal with BTW) and heck of a transmission shop, anyway upon re-assembly found I took out the drivers side inner cv joint also. So short question is who has the best price on a stronger drivers side half shaft assembly and where can I order it ????
Old Sep 27, 2007 | 07:31 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I think Mark Williams makes them. BTW, you can replace just the boot if you need to.
Old Sep 27, 2007 | 07:32 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I would just pick up a used stock unit. Your must have been on its way out due to a bad boot. Guys with big HP run the stock half-shafts.
Old Sep 27, 2007 | 07:37 PM
LoneStarFRC's Avatar
LoneStarFRC
To Drivers half shaft
