Service Column Lock
Old Sep 28, 2007 | 03:00 PM
BCC5's Avatar
BCC5
Default Service Column Lock
"SERVICE COLUMN LOCK" just appeared on the read-out screen on my '99. Then I can drive all of 10 ft. and the car shuts off. HELP?
Old Sep 28, 2007 | 03:18 PM
TM-Z06's Avatar
TM-Z06
http://forums.corvetteforum.com/show....php?t=1015483
Old Sep 28, 2007 | 03:20 PM
BCC5's Avatar
BCC5
Default Sorry...I didn't read above before posting!!
Sorry for the post, when I should have read the material already on the forum.
Old Sep 28, 2007 | 03:49 PM
87SAM's Avatar
87SAM
Also try a search on it, you'll have a 2 day read.
Old Sep 28, 2007 | 04:43 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
You can drive more that 10 feet, just don't go over 2 miles per hour!
Old Sep 28, 2007 | 04:50 PM
Quick Silver Z
Everything I ever needed to know on the subject...
http://www.thunderracing.com/catalog...d=220&pcid=156
http://www.corvettesofhouston.com/pr...products_id=54
http://www.ls1howto.com/index.php?article=24
Old Sep 28, 2007 | 05:09 PM
BCC5's Avatar
BCC5
Default The last link was the best...
Thanks for the links...the installation link nicely detailed the whole thing.
Old Sep 28, 2007 | 05:43 PM
Quick Silver Z
You're welcome, I had to make up for my "just don't go over 2 miles per hour!" wisecrack...
Old Sep 28, 2007 | 06:01 PM
88sk's Avatar
88sk
thunderracing is on ebay just put a $30 bid in & wait theyll give you a 2nd chance to buy for $30 instead of the $45 goin rate for these things.
Old Sep 28, 2007 | 07:40 PM
BCC5's Avatar
BCC5
Default Good idea but...
I went ahead and ordered on from the shop in Houston. My E-Bay experiences on car parts has been about 50/50 and not that good with electronic parts. So for a few bucks more I can have a little peace of mind.
I have "torn" into the knee bumper and removed the cover to find the connector and have pulled the cover off the fuses on the passenger side. When I get back from a hunting trip this weekend the part should be waiting at my door and 20 minutes later my black 99 will be back on the road.
Thanks for all the advice.
Old Oct 5, 2007 | 08:00 PM
BCC5's Avatar
BCC5
Default Done
Thanks to everyone for the help. The CLB from Corvettes of Houston was waiting at the door when I arrived back in town.
45 minutes later it was in and running.
All in well in my Corvette world (at least for now)
Cheers,
bc
Old Oct 15, 2007 | 10:40 AM
BCC5's Avatar
BCC5
Default It works but...
Having successfully installed the CLB and all was wonderful I now have found out two things.
One: Once in awhile I still get the "pull your key out..." message. I do it and all is well.
Two: Now that I have done the CLB I hear there is a recall by the mfg. to completely remove the plate for a permanent fix. Timing is everything!!!
Now on to a new project: To replace and relocate the oil pressure sensor. Yippee!
Old Oct 15, 2007 | 11:34 AM
Bugaboo's Avatar
Bugaboo
with the clb your wheel should not lock. check with the ignition off and see if that's the case. the CLB eliminates the actuator from the process. If all is well, do NOT let a dealer play with it. Most dealers don't have a clue...............
To Service Column Lock
