Oil Pressure sending unit failure record?
Old Sep 29, 2007 | 03:41 PM
Mxzx's Avatar
Mxzx
Default Oil Pressure sending unit failure record?
How is less than 500 miles from install to failure, time is about 6 months. Incredible!! I know there is a bunch of posts on this, but it there another sending unit that is better than the GM p.o.s??
Old Sep 29, 2007 | 03:51 PM
brookman's Avatar
brookman
did you see the other posts indicating how critical it is that you don't use over 15lbs of torque when installing it. Someone said if you tighten it until it bottoms out you have to apply over the maximum allowed torque.
Old Sep 29, 2007 | 03:53 PM
Mxzx's Avatar
Mxzx
Yeah I saw that, and it was put in very gingerly.
Old Sep 29, 2007 | 04:26 PM
ZeroHer0's Avatar
ZeroHer0
Changing mine out today...got an aftermarket one from one of the part shops. Only $35.
Old Sep 30, 2007 | 09:21 AM
rws.1's Avatar
rws.1
15 ft-lbs torque and scrupulously clean the terminal on th eold connector to ensure there is no oil residue form the old one.....
Old Sep 30, 2007 | 10:45 AM
Mxzx's Avatar
Mxzx
Does anyone know if the GM unit has any kind of warranty? I bought it from GMpartshouse.com.
Old Sep 30, 2007 | 11:14 AM
Richard Nogen's Avatar
Richard Nogen
They have a 1 year 12000 warranty. I went through 3 of them. Then I used the buick- pontiac sensor.
Originally Posted by Richard Nogen
I just used the Auto Meter along with the watts part & a 1/8 in close MM as I did not want the hose up top of the motor. I watched my last one fail on Thursday I had just changed my oil and cold start up my pressure reached 50 lbs then the gauge went crazy. I think the the heat expands the aluminum and ruins the seal. My wife has a 05 Bonneville and the oil pressure is always 50 - 60 lbs. So I hope this trick lasts.
Old Sep 30, 2007 | 11:57 AM
white top's Avatar
white top
WAS THERE ENOUGH room to fit that on top of the engine in the stock location & did you cut the hole or remove the intake.
Jerry
Old Sep 30, 2007 | 12:10 PM
Richard Nogen
There was plenty of room. I did leave the connector off. Then I slid the intake into place and had to lift the Brake Booster hose behind the fitting then I plugged the connector in. Every thing fits nice no strain on wires or hoses. I was not a fan of the hose across the top of the motor or extending the wires.
Old Sep 30, 2007 | 12:13 PM
Richard Nogen
Oh I forgot to mention that my last sensor was under warranty, and I got the dealership to swap me this one under warranty. So total out of pocket was 9.00 bucks.
To Oil Pressure sending unit failure record?
